Monday, Mar 24, 2008 at 19:05
Turk,
I travelled from Mt Augustus to Paraburdoo via Ashburton Downs last September. The road from Mt Augustus to the Ashburton Downs Road intersection was very good. I was advised at the resort that it is not a
well used road so it is isolated. We didn't see another vehicle all day. I was towing an offroad Jayco
Penguin. There are sections containing gibbers and there are sections where you need to cross quite a few gullies that are likely to cause you some problems when exiting rather than entering. The main Pigandy
Creek crossing could cause you a problem in terms of clearance for your van. It's rocky but there was a fairly high build up between the tyre tracks.
I found the road from the Dooley Downs/Ashburton Downs Road intersection to the Ashburton Downs/Paraburdoo Road intersection to be very rough in sections and would be the riskiest in causing damage to your onroad van IF you drive like a maniac.
While I was at Mt Augustus a couple of onroad vans and some conventional vehicles arrived and they came through from Carnavon,
Gascoyne Junction and Cobra route. I understand that most conventional vehicles/vans enter and exit this way.
Having said all this, what type of on road van do you all have? Some of the latest brands really have beefed up their chassis and springs as
well as their height. I've sold my
penguin and I'm getting a 16 foot single axle van and all they have to do to make it off road is add a 4' riser 15" off road tyres and heavy duty
suspension. I could have simply left the height as was and just put on heavy duty
suspension and 15' tyres and with that configuration I would have had no concerns about going that route and taken my time.
What length are your vans, are they all single axle? What is their height off the road/clearance at the rear?
In my travels over the last few years I have seen some onroad vans in some
places that has surprised me and they have done it because they were careful.
Also it could
well be that those roads will have been graded just before you do your
trip
Mt Augustus is a top place and it's like an emu egg is to a chook egg when comparing it to Ayres
Rock
294472
Follow Up By: jeepthing - Monday, Mar 24, 2008 at 19:10
Turk,
I tried to attach a couple of pics of the from Mt Augustus to the Ashburton Downs/Dooley Downs Road
intersection. If you are interested could you provide me your email address and I'll send them to you via email.
Roscoe
560350
Follow Up By: Turk - Monday, Mar 31, 2008 at 12:19
Thanks to all those who replied to my query re the trip to Mt.Augustis .The van that I have is a Jayco Freedom 17.6 tandem axle. I have underslung the axles to give me extra height and have travelled extensively in the outback and we drive to the road conditions.
Thanks once again
561790
Follow Up By: jeepthing - Monday, Mar 31, 2008 at 13:48
Turk,
Sounds like you have a bit of experience with outback roads and know what you are doing. I've had a look at a Jayco Freedom and I feel standard they would have enough clearance to not cause you any exit problems and you have raised your's a bit and you're going to be travelling in a group so I'd give it a go.
Enjoy the trip.
561804
