RE Thread 55445
Submitted: Monday, Mar 31, 2008 at 18:24
ThreadID: 56122 Views:1850 Replies:1 FollowUps:5
My origional post was about my GU clutch problem.The mechanic pulled out the box today and both the dual mass flywheel and the clutch are stuffed ! So in goes the exedy and all will be good .thanks for everyones input .
Giffo
Reply By: Dunaruna - Monday, Mar 31, 2008 at 18:28
Did you see it? Was the goo leaking from the flywheel?
AnswerID: 295827
Follow Up By: Member - Glenn G (QLD) - Monday, Mar 31, 2008 at 19:43
Going to take a look tomorrow morning !
Giffo
FollowupID: 561864
Follow Up By: Michael ( Moss Vale NSW) - Monday, Mar 31, 2008 at 20:53
Buy a solid flywheel, half the price and wot let you down again!! Michael.
FollowupID: 561881
Follow Up By: Dunaruna - Tuesday, Apr 01, 2008 at 07:35
He is, the exedy is a single mass flywheel.
FollowupID: 561953
Follow Up By: Member - Glenn G (QLD) - Tuesday, Apr 01, 2008 at 17:23
Had a look at clutch today and the flywheel is stuffed but not leaking oil.The clutch plate had 2 small bits of steel broken off next to the springs !also the bolts that holds the starter motor in the bell housing ,one had snapped off and one gearbox mount needs replacing,but will replace 2.Considering that I only paid 10k for a 98 Patrol 2.8TD with 150,000 and 4 new tyres I am still happy ! Hope to get out and use it soon .
Giffo
FollowupID: 562034
Follow Up By: Member - Glenn G (QLD) - Thursday, Apr 03, 2008 at 17:49
Picked up car today and what a difference !clutch is light and not noisier at all with the solid flywheel as some said may happen !
Cheers Giffo
FollowupID: 562459
