Where can i buy this?
Submitted: Tuesday, Apr 01, 2008 at 08:41
ThreadID: 56145 Views:3025 Replies:7 FollowUps:5
I am looking at making a flexible arm for the front of my car to hold the shower hose. Does anyone know where IImage Could Not Be Found can buy something similar to the flexible metal shown in the attached picture?
Thanks for your help.
Ps, sorry about the quality,it was taken by my phone.
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
Reply By: Member - Noldi (WA) - Tuesday, Apr 01, 2008 at 11:40
Hi Lyndon,
I bought something similar for my GPS off ebay for around $12, suction cap base I think would be stong enough to hols a shower head and easy to remove when travelling. Thanks for the idea I am going to try it as well.
Rgds
Ian
AnswerID: 295940
Follow Up By: Member - lyndon K (SA) - Tuesday, Apr 01, 2008 at 15:57
Thanks for the feed back but in my situation i would like to get the rose away from the car a little more, not heaps, just don't want to have to lean on the car for a shower.
Cheers Lyndon
FollowupID: 562014
Reply By: Member - Pedro the One (QLD) - Tuesday, Apr 01, 2008 at 13:09
Hi Lyndon ........
Just a suggestion : could you not get another lamp [ from 2nd hand shop/St Vinnies/etc ] dismantle it and re-use the flexible tube ? Is it wide enough to feed the hose through ??
Or just dis-mantle the one you have, use it and get another lamp to replace it ?
Great idea, though .... will be watching the responses in case that flex-tube is available.
AnswerID: 295946
Follow Up By: Member - lyndon K (SA) - Tuesday, Apr 01, 2008 at 15:58
thanks for your reply but the arm is to week and to short to support the rose.
Regards Lyndon
FollowupID: 562015
Reply By: str- Tuesday, Apr 01, 2008 at 13:21
microphone goose neck maybe. looks just like that
it has a thread on both ends. you can get a base that is used to screw to podiums lecturns etc and a mic holder on the other end would fit a hand held shower head.
AnswerID: 295949
Reply By: str- Tuesday, Apr 01, 2008 at 13:48
gooseneck something like this
AnswerID: 295952
Follow Up By: Member - lyndon K (SA) - Tuesday, Apr 01, 2008 at 15:59
dead link?
FollowupID: 562016
Follow Up By: str- Tuesday, Apr 01, 2008 at 16:03
yeh.. not so crash hot with this stuff.. see the link below.
Jaycar or anywhere should have the base you could screww to the car and mic holder too..
FollowupID: 562018
Reply By: KSV. - Tuesday, Apr 01, 2008 at 14:55
Look here
AnswerID: 295957
Follow Up By: Member - lyndon K (SA) - Tuesday, Apr 01, 2008 at 16:00
might just do the trick, thanks
FollowupID: 562017
Reply By: Member - Roachie (SA) - Tuesday, Apr 01, 2008 at 16:09
Why not use a telescopic tent pole; mount it on your bullbar at the appropriate angle to get it away from the car's front end. Secure it using an occy strap etc while you're showering.
Another idea might be to use an old beach umbella pole....the type that has a wing nut half way up and a series of rachets around it so you can adjust it to various angles. I have one of these at home. They also make an excellent pole for holding up a flouro camp light.
I like to carry gear that has more than one use.
Roachie
AnswerID: 295965
Reply By: Member - Alan H (QLD) - Tuesday, Apr 01, 2008 at 17:14
If you have a roof rack - a simple piece of alloy or even wood to slide out and hold shower head and then retract before driving off.
I had a piece of wood for this and it worked well. The wood gave a better grip for the bungy cord to hold it in transit.
AnswerID: 295973
