Coil Rite air bags
Submitted: Saturday, Apr 26, 2008 at 08:31
ThreadID: 57002 Views:3070 Replies:1 FollowUps:4
Well the Coil Rite bags are in the Nissan, a little claret on the melon courtesy of the tow bar the only issue.
$150 delivered from the states and they were received 5 days after order.
I would rather spend the money in Aus, though I can not justify spending $350 on the same item here.
Reply By: fouldsie - Saturday, Apr 26, 2008 at 19:33
Gday I am considering putting polyair in my 100 series.. Are Coil Rite a similar product and if so what is the online ordering web address that you used.. Obviously reliable if delivered 5 days after order.. Thanks
Derek
AnswerID: 300645
Follow Up By: blue one - Sunday, Apr 27, 2008 at 08:40
G'Day,
You will have to do some surfing on the net as the model numbers used out don't reference the manufacturers. I found some good information on the Nissan forum and I would expect the same info would be available on the Toyota site. Then I looked at the manufacturers web site and found dealers checked the dealers web site and ordered the kit. Sounds hard though in reality it would have been about 3 hrs work. Looked at both poly airs and coil rites are available from Truck Spring (Just Google it). They would have ones to suit your 100 series. If you have trouble with stock issues leave a thread and I will suggest some other suppliers.
Good Luck
FollowupID: 566849
Follow Up By: Biglinz - Sunday, Apr 27, 2008 at 22:25
Coil-rites are the same as the Polyairs and are made by Firestone. I have them and can't fault them.
FollowupID: 566941
Follow Up By: Ray - Monday, Apr 28, 2008 at 08:44
trucksprings.com
FollowupID: 566980
Follow Up By: Outbacktourer - Monday, Apr 28, 2008 at 13:50
The products are similar but the method of attaching the air line is different. The Polyairs have a nipple that you attach the hose to and hose clamp applied. the Coil rites have a O ring arrangement that you slide the hose into and it self locks. Personally I prefer the way the coil rites work if for no other reason than there is no clamp to break or catch on anything.
OT
FollowupID: 567025
