Weight Ditriution Bars with Tregg Coupler?
Submitted: Saturday, Apr 26, 2008 at 14:15
ThreadID: 57008 Views:2593 Replies:4 FollowUps:5
Hi all,new to the Forum. Can anyone help in regards to fitting H/R Weight Distribution bars to a Expanda O/Back with Tregg Coupler?
Freinds have had one fitted to a Coramal Camper by the dealer ,no problems, but Jayco seemed to be reluctant to fit one saying its not needed?
I understand that it would need to be removed when serious 4X4.
Just trying to even up the weight to the front of the Hilux 4x4.
Any thoughts or help would be much appreciated.
PS- have very steep downward driveway, would the bars foul the drive by hanging down too low?
Reply By: Vivid Adventures - Saturday, Apr 26, 2008 at 14:41
father in law's driveway is a bugger to reverse his van into with the bars on... you take them off before reversing up it.
There should be no reason why wight distribution bars couldn't be fitted, except the obvious - that the tregg hitch is designed for freedom of movement and the bars are designed to limit same... and if your Jayco is causing that grief on the bitumen, what's it going to do off the road?
AnswerID: 300587
Follow Up By: lewishamlad - Saturday, Apr 26, 2008 at 15:05
Have no props with the van Swaying Etc on the road but would like to level up slightly & add a little weight back to the front
FollowupID: 566709
Follow Up By: Member - David P (VIC) - Saturday, Apr 26, 2008 at 15:12
What is your loaded ball wt? .....silverback
FollowupID: 566711
Follow Up By: lewishamlad - Saturday, Apr 26, 2008 at 17:01
if this is Calculated @ 10% of van weight being towed around 168- 173kg for ball weight
FollowupID: 566743
Follow Up By: Member - David P (VIC) - Saturday, Apr 26, 2008 at 18:36
how about thread 57002?.....silverback
FollowupID: 566774
Follow Up By: Member - Graham H (QLD) - Saturday, Apr 26, 2008 at 19:08
A guess is not near enough Take it to a weighbridge. Like most people you may be in for a surprise.
FollowupID: 566787
Reply By: Dunaruna - Saturday, Apr 26, 2008 at 15:49
It will not cause any problems if setup correctly.
AnswerID: 300602
Reply By: snailbait (Blue mntns) - Saturday, Apr 26, 2008 at 20:35
lewishamlad
If you have Coil springs u put in Polair air bags and u pump up the polair to 30 lbs air pressure and u do not need bars . My set up of towing does not need Bars
Life MEMBER snailbait Oberon HF RADIO CLUB VKE237 mobile 7661
AnswerID: 300661
Reply By: Member - Jim - Sunday, Apr 27, 2008 at 19:11
Lewishamlad,
I think this has something to do with the placement of the Tregg hitch on a Jayco Expander rather than anything else. It has something to do with the ADR and towing heights of a tow ball which makes it awkward for a WDH.
As you have stated you have friends with a Coromal camper who have no problem, I have a Capri Pioneer XC van with the same arrangement, no problem.
It is worth a call to Hayman Reece direct to find the answer for your particular application.
Regards,
Jim
AnswerID: 300803
