glazed 2H motor
Submitted: Friday, Jun 27, 2003 at 22:09
ThreadID: 5705 Views:6840 Replies:13 FollowUps:15
I need to deglaze my 2h toyota turbo motor.
R there any products which can help me overcome this problem apart from redoing the rings again.
much appreciated.
Reply By: Martyn (WA) - Friday, Jun 27, 2003 at 23:22
Ray,
I don't think there is anything, the only way to really fix this is to degaze the bores with a honer, as far as I know. Then when you start the engine again make sure it's loaded as soon as you drive it, I towed a loaded trailer up a hill about six times as soon as I started the engine up, this helped. This is what I've been led to believe.Keep the shiny side up
AnswerID: 23697
Follow Up By: ray - Saturday, Jun 28, 2003 at 18:05
I'll certainly keep the shiny side up as long as my ass points to the ground.
FollowupID: 15892
Follow Up By: Simon - Sunday, Jun 29, 2003 at 20:14
A hand full of Bon Ami in the air intake will deglaze it.
FollowupID: 15930
Reply By: Truckster (Vic) - Friday, Jun 27, 2003 at 23:47
Honestly as Martyn says.
Other way is long hard hauls, recommended for ALL diesels anyway.
Good run to bleep ney fixes mine up, coast road there, Sesame st home
AnswerID: 23699
Reply By: Member - Royce- Saturday, Jun 28, 2003 at 01:05
How have you decided that you need to deglaze your motor?Royce www.funshow.com.au
AnswerID: 23700
Follow Up By: ray - Saturday, Jun 28, 2003 at 08:16
Its easy well the people who built the motor tell u so. cost another $500.00.
Ongoin drama with an after market turbo from turbotech in perth, it blew up and consequently keeps pumpin oil. plus there r only flat roads in karratha oh yeh - one hill.
FollowupID: 15876
Reply By: Bob Y. - Qld - Saturday, Jun 28, 2003 at 06:21
Ray,
The advice given to me, by the service manager of north west qld dealer, was a handful of Bon Ami, down the intake. I laughed, so did he, but felt he wasn't speaking in jest. Feel this was their modus operandi, takes 10 mins, charge 8 hours.
There's a mob that advertise a service to bring glazed motors back to standard, think it's in 4WD Monthly. Hooroo...
AnswerID: 23704
Follow Up By: ray - Saturday, Jun 28, 2003 at 08:19
have heard of the bon ami remedy and will give it a go after spending $80.00 on this stuff from Qld I tracked down in the magazine.
thanks
FollowupID: 15877
Reply By: Kev - (Cairns,QLD) - Saturday, Jun 28, 2003 at 12:26
I have heard of people throwing a hand full of Ajax down the air intake, im not sure about this but made me laugh.
AnswerID: 23711
Follow Up By: ray - Saturday, Jun 28, 2003 at 18:06
last resort -- bon ami -- it is better than ajax
FollowupID: 15894
Follow Up By: Kev - (Cairns,QLD) - Saturday, Jun 28, 2003 at 18:50
Iv never heard of bon ami ! (sounds french)
FollowupID: 15901
Reply By: peck - Saturday, Jun 28, 2003 at 12:42
I used to work for Lincoln Electric and a common problem with Perkins diesel driven welders was glazing of the bores. Persil down the air intake used to cure the problem.
AnswerID: 23713
Reply By: desert - Saturday, Jun 28, 2003 at 13:48
Any abrasive substance you pour down the throat of your engine is going to do the job on, cylinder bores,piston rings, valves and anything that gets past the rings will find it's way into the oil and then the bearings. A great way to completely stuff your engine, top to bottom. Do it properly or not at all. Lift the head off and have the bores deglazed by a professional cylinder honer, who, if he knows his trade, will measure the bore for excessive tolerance to see how much lee-way he has got to work with. It might be that the wear is excessive and no amount of deglazing is going to substitute for metal already worn away. You may not want to hear the results of his measurments!
AnswerID: 23718
Follow Up By: ray - Saturday, Jun 28, 2003 at 18:00
motor has only done 2000ks. new pistons rings etc etc
FollowupID: 15889
Follow Up By: Truckster (Vic) - Saturday, Jun 28, 2003 at 18:23
If the motor has only done 2000klms.... take it back to them, and tell them to fix it - Free...
They couldnt be that jewish to rebuild a motor and NOT hone the bores, after all it takes around 1 minute per bore.. WOW SIX MINUTES.
Small claims court, Consumer Affairs would also help.
Something doesnt gel with all of this.
FollowupID: 15898
Follow Up By: Member - ADRIAN- Tuesday, Jul 01, 2003 at 23:58
i agree with desert any of that stuff is abrasive /might as well drive arround with air cleaner off[ probably do less damage]
whats the problem -tomuch blow by-oil burning/may be turbo if fitted not set up properly. in my opinion 2h is not suitable for fitting of turbo unless you fit mech governor pump as well. a lot of pressure from turbo gos down balance tube on venturie via pumps and into crankcase. these engs breeth afair bit normaly.
glaze is usualy abuild up of varnish etc on cyl walls.we have removed this succesfuly on petrol engs with agood detergent/just pour into cyls 2 at atime let soak clean out and sqirt crc or sim to stop rust .can be done with head on . we use nth power deturgent.
however if your eng has only done 2000k since rbuild should not need deglaze take
it back to the rebuilder/ if you fill it with bon amy or any other abrasive it will be a way out for the rebuilder
FollowupID: 16137
Reply By: kezza - Saturday, Jun 28, 2003 at 14:49
Glazing is a symptom of some friction modifiers in oil. (teflon may have been one of them)
Years ago when friction modifiers first became popular in motor oils many engines became glazed. We ran a fleet of vehicles and had some problems with glazing and after some homework found that among others Penrite oils will deglaze a motor as they do not use friction modifiers and use a slightly different lubrication and cleaning principle. It allows just enough wear to prevent glazing. (but I bet your engine will outlast one run on FM oil)
(I forget the exact details)
If anybody can add to this please do - Needless to say Ive been using penrite ever since and havnt had the problem.
I must say it certainly will keep you engine in great condition. (both sludge and glaze free)
Toyota dealers seem to use an oil that leaves deposits on motor interior surfaces check your dipstick chances are theres a brown residue halfway up the dipstick - dont know if its related to the glazing problem as well but I noticed it on a petrol toyota celica I bought that had been serviced by toyota all its life - it dissapeared after a few months with Penrite in the donk.
I dont know the severity ray of your problem but as for the ajax trick - I worked with diesel field mechanics in victoria in the 70s and it was a great mechanics joke - it worked - but also kept them in business.
kezza
AnswerID: 23722
Follow Up By: ray - Saturday, Jun 28, 2003 at 18:02
Looks like the penrite oils seem a 1st base trick.
FollowupID: 15890
Reply By: sean - Saturday, Jun 28, 2003 at 15:54
Ajax!!!!
I had a petrol motor once that was using a bit too much oil. My cousin said pour a bit of ajax down the carby and it will help to rebed the rings.
So I did.
I reved the the thing as hard as I could then watched the motor cough its way down to almost stall as I regulted the ajax down the throat of the carby. The treatment went on for about 5 minutes with the motor picking up revs to about 5000 then back down again as the Ajax went in.
After the treatment the motor used so much oil that I could not drive it and still see out my rear view mirror. I wrote the car off and did not drive it again.
And gues who ended up with the wreck - My Cousin....
Sean
AnswerID: 23725
Follow Up By: ray - Saturday, Jun 28, 2003 at 18:08
sounds like a close nit family -- friends like that who needs enemies
FollowupID: 15895
Reply By: Member - Bonz (Vic) - Saturday, Jun 28, 2003 at 16:00
ray,
the best way tpo deglaze a toyo is to buy a Patrol!
Laterally literalSo many places to go!
So much work to do :0(
AnswerID: 23726
Follow Up By: ray - Saturday, Jun 28, 2003 at 18:04
thanks mate --- thats the reason I got a toyota
FollowupID: 15891
Reply By: Truckster (Vic) - Saturday, Jun 28, 2003 at 18:14
You say the motors been rebuilt 2000klms ago, new pistons rings etc, yet they didnt hone the bores? What sort of hacks are they?
There is no way on the planet it would glaze up in 2000klms.
Someones pulling your chain...
AnswerID: 23738
Follow Up By: diamond (bendigo) - Saturday, Jun 28, 2003 at 18:20
thats exactly what i was thinking.
maybe he meant 20000ks.
id be taking it back to the bloke who rebuilt it.
looking foward to september(landcruiser park/fraser island)
FollowupID: 15896
Reply By: pat - Sunday, Jun 29, 2003 at 21:00
i dont know wether i supposed to advise companies on this forum but may i suggest talking to Cost Effective Maintenance (www.costeffective.com.au).
Ihave trialeed some of their pruducts to cure glasing and severe sludging of a 3.2l Jack engine, that my mechanic had apart to replace shot hydralic lifters. He found severe sludging in all oil chambers that he literally had to shovel out.
Also discovered that the lifters assemblys had suffered premature wearing,due to acumulation of sludge blocking critical oil passages.The rattles have disaapeared somewhat with new lifters but unfortunatly will always have some until i replace the whole rocker assemblies.
Since been put back together have trialed some of this pruducts to alleviate these problems and have found definite improvement in oil presure and engine performance.Also have a 2wd hilux which is very good condition and after posiitive responses in the jack ,used in the hilux. Again a very noticable improvement in engine and gearbox performance and distinct reduction in engine noise.
I also recommend the use of penrite oils .I find these oils deliver exactly what they promise and since using them found things seem to stay cleaner and operate more effeciently.
AnswerID: 23799
Reply By: Ray - Monday, Jun 30, 2003 at 14:54
Hi Ray
Having read most of what has been posted to your request I have some words for you.
All the talk of different oils does have some validity, there are some engines that just do not run well on some oils. i sugest you run on the oil that the manufacturer recommends they spent a lot of money on the research.
If you engine has been recoditioned and new rings fitted without the bores being honed this would be!!! not in the normal practice of doing things.
Any good long drive after a rebuild will bed the rings in, just do not let it idle.
Do it properly do once
Hope this helps Ray
AnswerID: 23855
Follow Up By: tex1972 - Thursday, Jul 03, 2003 at 19:00
Any decent engine rebuilding mob should have told you how to run the engine in.If you can get on a dyno give it a whirl thats how they run in heavy diesel engines before delivery
FollowupID: 16233
Follow Up By: kezza - Friday, Jul 11, 2003 at 00:34
Some Validity????
Oils AINT Oils Sol!!
Oils Play a BIG part.
kezza
FollowupID: 16585
