Air Bag light on dash
Submitted: Wednesday, Apr 30, 2008 at 13:58
marknz
I just installed spotties on my 2007 Hilux and the airbag warning light has come on.
Does anyone have any suggestion as to how to reset/turn it off.
Any help would be great.
Reply By: Member - Olcoolone (S.A) - Wednesday, Apr 30, 2008 at 13:59
Take it to Toyota as you may have a problem, It would be under warranty.
Regards Richard
301318
Reply By: autosparky - Wednesday, Apr 30, 2008 at 19:38
did you disconnect the battery?
301365
Follow Up By: marknz - Thursday, May 01, 2008 at 06:27
I took the feed for the spotties off the red/yellow and black wires on the head lights. I didn't disconnect the battery.
567495
Follow Up By: autosparky - Thursday, May 01, 2008 at 07:57
you may have disloged a plug to the air bag wiring whilst running the wiring(air bag wiring runs in yellow sleeving )or it just had a bad day and needs to go back to the dealer to remove or reset the code.
567500
Follow Up By: marknz - Thursday, May 01, 2008 at 13:49
I did unplug a connection on the steering column - on top of the key barrel that from memory had a yellow sleeve.
Can it be reset easily?
567549
Follow Up By: autosparky - Thursday, May 01, 2008 at 20:58
try disconnecting the battery (leave diconnected for at least 1 minute reconnect battery) if that fails it will have to go back to the dealer for reset
567622
Reply By: Member - Phil G (SA) - Wednesday, Apr 30, 2008 at 20:47
How/where did you wire in the spotties?
301380
Reply By: Member - Mike DID - Thursday, May 01, 2008 at 23:40
On Pajeros, the ONLY way to reset the Airbag light is to take to a Dealer. It may be the same on yours.
301595
Reply By: Dunaruna - Friday, May 02, 2008 at 16:48
When you disconnected the SRS loom a hard fault code was logged, this activates the warning light. The only way to clear the fault code is with a scanner.
301710
