Remote door lock
Submitted: Thursday, May 01, 2008 at 13:59
Member - Ken I (QLD)
The remote fob for my 100 series Land Cruiser has stopped working.
I have replaced the battery but it still will not operate. Can anyone tell me if it may be a fuse problem and if it is, which fuse is it related to? I have checked the user manual but cannot find a reference to it
Reply By: Member - Footloose - Thursday, May 01, 2008 at 15:02
Have you checked the battery connections inside the FOB ?
301458
Reply By: Member - Jon W (QLD) - Thursday, May 01, 2008 at 15:33
Ken,
We had a similar problem with our '03 Patrol. Dealer initially tried to reprogram it but then both remotes were replaced under warranty.
For what it's worth.
Jon W
301464
Reply By: Member - Graham H (QLD) - Thursday, May 01, 2008 at 17:19
A new one is $38 from Toyota or look on Ebay for about $25 used and easy to reprogram
301495
Reply By: Gone Bush (WA) - Thursday, May 01, 2008 at 17:29
Not familiar with that particular one but if a remote control that has a transmitting LED on
the tip (like all TV remotes) is not working and the battery is OK, do this:
Set your mobile phone to camera, aim the R/C at the camera lens and look at the screen. You will see the LED flashing if it works and not flashing if it's U/S.
301496
Reply By: Vivid Adventures - Thursday, May 01, 2008 at 18:10
Mine died eventually...
water probably.
Anyways, replacement one from Toyota was about $30.
The only problem was that the whole system needed resetting because it had got to the limit of supported number of remotes, and the reprogramming took the dealer quite a bit of time...
You know, disconnect battery, reconnect it after x minutes, turn the car to on, enter a code into the radio, turn the key to accessories 3 times, spin on your head, count to ten, put the key in your ear, scream blue murder and finally it was working again... oh, and $85 bless their cotton socks.
301503
Follow Up By: TD100 - Thursday, May 01, 2008 at 19:22
ROFLMAO! and thats about what they do to program these things.cut a long story short the dealer replaced one of
mine they lost,i sat in the car and watched for an hour as the guy tried to get this thing to program.what a saga!even he was getting pi$$ed off because it just didnt want to happen.eventually he got it,must have had his tongue hanging out the wrong side! hahahaha.cheers Paul
567610
