Sydney Yeo Chasm
Submitted: Saturday, May 03, 2008 at 11:25
ThreadID: 57223 Views:1908 Replies:2 FollowUps:4
has anyone been to Sydney Yeo Chasm which is east of Connie Sue Hwy
Reply By: Tony MD - Saturday, May 03, 2008 at 17:42
Not yet but will be there in July if you can wait?
Cheers, Tony.
AnswerID: 301857
Follow Up By: Member - Rod V (WA) - Saturday, May 03, 2008 at 19:35
I'll be thinking about going round 20th leaving Useless Loop when they have a shut down
FollowupID: 567976
Follow Up By: Member - Rod V (WA) - Saturday, May 03, 2008 at 19:36
Ok and see you have a HF mounted on your left rear carrier where do you get then
FollowupID: 567977
Follow Up By: Tony MD - Sunday, May 04, 2008 at 16:12
Rod, the setup in the picture is a Strong Arm carrier with a small section of 8mm aluminium angle bolted & braced to the wheel carrier. I used the same setup on a Kaymar wheel carrier.
Now have a new rear bar (thanks to hitting a Tree) & there are antenna mounts welded to both wheel carriers. Works fine.
Cheers, Tony.
FollowupID: 568054
Reply By: GerryP - Saturday, May 03, 2008 at 18:23
Was there a coupla years ago. If you're heading along the Connie Sue, it's well worth a visit. Nice change of scenery and not a bad place to camp for a couple of nights if you're looking for a lay-day.
Gerry
AnswerID: 301870
Follow Up By: Member - Rod V (WA) - Saturday, May 03, 2008 at 19:37
Theres good water nth of Cooper hills at and old drilling camp you need a pump to get at it
FollowupID: 567978
