100 SERIES AIR FILTER LIGHT
Submitted: Thursday, May 08, 2008 at 14:43
ThreadID: 57385 Views:7273 Replies:5 FollowUps:2
Turbo diesel air filter light comming on when I put my foot down,found the same happening while cruise controle is on.
Have changed filter and made no difference.
Your comments please......
Reply By: Member -Signman - Thursday, May 08, 2008 at 14:56
Simple solution..
Don't put your foot down & don't engage cruise control !!
AnswerID: 302693
Reply By: Member - Tour Boy Springsure- Thursday, May 08, 2008 at 15:55
Check that the hoses to and from the air cleaner haven't got a kink or are going soft. This will cause the hose to suck in on itself under heavy acceleration (2.2l deisel hiluxes did this) and cause a restriction, loss of power and the warning light.
Do you have a snorkel fitted? Some have a dry foam filter jammed in them that most people don't know about untill they clog up.
Just a thought.
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 302700
Reply By: i lean - Thursday, May 08, 2008 at 16:21
I do have a snorkel fitted I will check for the foam tonight
why do they do that
AnswerID: 302708
Follow Up By: Member - Matt (Perth-WA) - Thursday, May 08, 2008 at 16:39
The light is to indicate a restriction...so somewhere you are restricting the intake air before the sensor.
The Snorkel may be too small for the vehicle and apart from adding another I guess you will live with it.
Is the filter element original? Have you changed to foam? You said its clean but it may be too restrictive from the OEM one.
As others have said look for soft hoses etc or places where they might have kinked and cause a restriction.
All the best
Matt
FollowupID: 568833
Reply By: TD100 - Thursday, May 08, 2008 at 21:14
check the hoses from the switch to the top and bottom of the air barrel,make sure they are connected and not kinked.is the performance down?if it isnt maybe the switch is faulty only.food for thought. cheers Paul
AnswerID: 302779
Reply By: GerryP - Thursday, May 08, 2008 at 21:20
Maybe they're not all the same, but my 105 (1HZ motor) has two sensor rubber lines to the air cleaner, sensing only across the air filter element, running back to a pressure switch. Therefore, if the light is coming on, it means that the air cleaner is stuffed/blocked, the sensor lines are kinked, blocked or disconnected, or there is problem with the pressure switch itself. Since the sensor measures pressure drop across the filter, blockages upstream (such as a blocked snorkel) will not cause a higher pressure drop across the element - in fact, it will do quite the opposite.
Gerry
AnswerID: 302780
Follow Up By: stocky - Saturday, May 10, 2008 at 15:10
or when last serviced someone put the lines back the wrong way round.....
FollowupID: 569203
