Air Springs
Submitted: Saturday, May 10, 2008 at 09:29
ThreadID: 57442 Views:1831 Replies:2 FollowUps:1
I have just purchased a pair of Firestone air springs for an 80 series LC. In the kit are two circular urethane discs approximately 3" in diameter but I do not know where they fit. The fitting instructions do not show these discs. I have been in contact with the supplier but the answer that I got was inconclusive. Any of you people had a similar problem? (fitting I mean)
Reply By: dedabato (SA) - Saturday, May 10, 2008 at 15:58
Hi Ray,
I just finished installing air bags on my 80 series LC and didn't need to use the spacers provided as they are for modified suspension. Since my suspension is a standard version I did not needed them.
I hope this will help...
dedabatoImage Could Not Be Found
AnswerID: 303064
Follow Up By: Ray - Saturday, May 10, 2008 at 19:52
Thank's very much
FollowupID: 569257
Reply By: Member - Clive G (NZ) - Saturday, May 10, 2008 at 20:37
Hi Ray.
I have 100s L/Cruiser that I fitted Polyairs to some 4yrs ago. This kit also had those disks, do they have a hole in middle and are about 5-6mm thick? If so they go on top of the air bag to stop chafing from the spring tower.
Cheers, CliveG NZ
AnswerID: 303118
