97 troopy transfer noise
Submitted: Monday, Jun 30, 2003 at 20:36
ThreadID: 5749 Views:2018 Replies:3 FollowUps:1
Some may remember my recent post on transfer case noises, dropped the oil out today and it was metalic gravy so it's looking like a rebuild, question, is there an
after market gear set, bearings etc (rebuild kit) available, if so where from and approx $.
thanks.
Reply By: GOB member vic - Monday, Jun 30, 2003 at 22:12
goodday phil
might be cheaper to look around for second hand case young fella i know supposed to hed ad off around oz decided to do bearings in t/c when pulled to bits 1 gear and 1shaft stuffed $1700 for 2 bits $2000 for s/h box nearly had to cancel trip but i think they are back on track
stevewatch this space
only 40 sleeps to go but whose counting
AnswerID: 23902
Reply By: Steve from Drive Systems Victoria - Tuesday, Jul 01, 2003 at 11:19
Gympie four wheel drive wreckers have change over reco's, sorry lost the phone number, ring Telstra.
AnswerID: 23934
Follow Up By: Phil - Tuesday, Jul 01, 2003 at 12:17
Thanks for that but I should've mensioned that I'm in the mornington
peninsula area vic. anyone doing local change overs or does someone know good 4x4 mechanic down here. I'd like to steer clear of Toyota unless there's no other option.
FollowupID: 16043
Reply By: Bat - Tuesday, Jul 01, 2003 at 19:48
I am in Canberra ring a mob called Autoco my mate got mine parts from there transfer case bearing kit 411.00 transfer case idle gear 603.90 I also reraced the main box 500.20 kit clutch400.00 plus labour all up a bit over 3000 Bat.
AnswerID: 23984
