Which Inverter?
Submitted: Tuesday, May 13, 2008 at 16:44
pheonix
I am looking to buy an inverter for our trip. This will be used to charge camera batteries, the kids nintendo DS's, laptop and other small things.
Do I have to get a pure sine wave or will a modified sine wave be okay. I have read so much but am confused as some sites say MSW is okay but others say pure sine wave is the only way to go. I was looking at around a 500 - 600w. Any brands people can recommend.
Pheonix
Reply By: _gmd_pps - Tuesday, May 13, 2008 at 17:12
Synergex 500W Pure Sinewave
is what I use in my truck
I also have a 2000W in the slide-on.
pure sine wave all the way .. some cheap charges burn up with
modified sine wave ...
good luck
gmd
303615
Reply By: Sand Man (SA) - Tuesday, May 13, 2008 at 18:18
Pheonix,
For the majority of uses, including those you have specified, a modified sine wave inverter of around 300 watts will be sufficient for your needs.
Your laptop may, or may not, operate on a modified sine wave inverter. Most do but some don't.
If you can justify the initial cost, a pure sine wave inverter will be a very good investment. A 300 watt unit will power most things you are likely to need it for.
There is nothing wrong with the Jaycar units.
To give you an idea of cost, a 300w pure sine wave inverter is listed at $199. A 600w pure sine wave unit is $349.
Bill.
303631
Reply By: lifeisgood - Tuesday, May 13, 2008 at 20:31
The prices of
inverters have come down a lot so its worth considering the pure sine wave for your laptop, Most appliances are designed for 240ac supply (sine waveform) not a chopped imitation of one---so better to use that.
Perhaps 300Watt sine would meet your stated requirements rather than a bigger Modified SW
I started with a 140w MSW but will move up to 300W sine next.
303657
Reply By: GerryP - Tuesday, May 13, 2008 at 21:38
Hi Phoenix,
Obviously pure sine wave is always going to supply "cleaner" power, however, I have only ever used MSW for everything you have mentioned and have never had a problem (touch wood!). I reckon you'd have to be unlucky, but it's always possible that Murphy may stick his nose in.
Gerry
303676
Reply By: Mainey (wa) - Wednesday, May 14, 2008 at 08:28
Pheonix,
Do it once and do it right
PURE sinewave offers the safest performance for ALL items
All other systems are just a cheaper compromise !
(ie, they have no technical advantage, other than a cheaper price)
** Make sure it uses an internal FAN cooling system **
Mainey . . .
303713
Reply By: Robin Miller - Wednesday, May 14, 2008 at 11:41
Hi Pheonix
A Jaycar MI-5108 600W MSW will suit you requirements quite nicely , they are compact and currently about $160 retail.
You can buy this size cheaper from ebay but I would buy from a place where you can check its operation and return if not happy.
I always think 600w is a great size as you can run a small angle grinder or drill off them and I find these are powerful and useful
tools when out and about.
303729
Reply By: Member - Paul S (VIC) - Wednesday, May 14, 2008 at 14:46
We use an power adaptor which plugs into the cig socket. Its main function is to run our laptop and recharge its battery, so the normal transformer which comes with the laptop is not used. With this system you are not going from DC to AC and then back to DC. Much less power used and cost around $70 a couple of years back from Dick Smith.
Paul
303753
