2003 td4.2 patrol
Submitted: Friday, May 16, 2008 at 17:18
ThreadID: 57674 Views:3715 Replies:12 FollowUps:18
have a 4.2 td patrol that is gutless, will just a 3"exaust and a tune up be enough or should i upgrade the turbo as well
Reply By: Member -Dodger - Friday, May 16, 2008 at 17:27
Go the whole hog, Turbo dump pipe and the 3" exhaust plus a full tune up on a dyno.
Exy but worth the effort.
Cheers Dodg.
AnswerID: 304183
Reply By: timbo2 - Friday, May 16, 2008 at 17:58
did u find the motsons upgrade good?at present i get 5kms per liter of fuel, does the upgrade improve this.thanks
AnswerID: 304192
Follow Up By: donk - Friday, May 16, 2008 at 20:15
If you are only getting 5 klms per litre i think you have a problem with it that needs to be sorted
My standard 2005 (i assume yours is intercooled as well) is always loaded to gvm & consistantly returns 8 klms per litre & when we are towing our 23 foot van weighing approx 2700 kg it consistantly returns 5 klms per litre
In doing ther mods suggested you may fix the problem anyway but i would be getting the thing running right before carring out any mods
Regards Don
FollowupID: 570283
Follow Up By: timbo2 - Saturday, May 17, 2008 at 07:16
yes its intercooled, has trouble doing a hill start with a trailer on the back!
FollowupID: 570339
Follow Up By: Member -Dodger - Saturday, May 17, 2008 at 13:22
Yes the Motson upgrade made a huge difference to the power and drivability of the vehicle.
Vehicle when not towing and part loaded returned14 ltr per 100 klms or 21 mpg and when towing 1.8 tonne van and vehicle fully loaded 18 ltr per 100 klms or 16mpg. Which was nearly the same as before only a slight improvement.
When you increase the power and torque one tends to use it so the real gain was not in economy but in drivability.
Cheers Dodg.
FollowupID: 570409
Follow Up By: timbo2 - Saturday, May 17, 2008 at 17:10
thanks, looking forward to same economy.
FollowupID: 570439
Reply By: Ozboc - Friday, May 16, 2008 at 20:24
HI there , had the car been "gutless" since you got it ?? or its been a slow progression downhill ??
turbo and exhaust mod will make a HUGE difference , but just remember these diesel as are not the same as petrol motors.
Boc
AnswerID: 304213
Follow Up By: timbo2 - Saturday, May 17, 2008 at 07:14
yer, thanks it been gutless from day 1,nissan say its within spec and wouldnt touch it.
FollowupID: 570335
Reply By: Member - Matthew C - Friday, May 16, 2008 at 20:58
The exhaust mod is useless without the turbo mod and the turbo mod is useless without the exhaust.
Turbo mod,dump pipe,exhaust and dyno tune and youll love it.Dont do half a job on these TD42's .
Matt
AnswerID: 304218
Follow Up By: timbo2 - Saturday, May 17, 2008 at 07:15
thanks
FollowupID: 570337
Follow Up By: sfletch - Saturday, May 17, 2008 at 18:22
i was thinking of exhaust for my hilux but you are saying useless without other mods,any more info on that??
FollowupID: 570452
Follow Up By: Member - Matthew C - Sunday, May 18, 2008 at 19:47
Different setup all together tell me what you have and i will advise accordingly.
Matt
FollowupID: 570607
Reply By: Trevor R (QLD) - Friday, May 16, 2008 at 21:27
I agree with one poster, that 5k's per litre is woeful from this car, should be closer to 7 so there could well be a problem causing lack of power at the same time???
I personally would start with the lowest common demoninator in a major power upgrade and keep adding bits toward this major upgrade until you are happy. 3" exhaust and dump pipe will be a great start and necessary for any further mods anyway so do this and see what you think.
Where are you, if in Brissy I can point you in the right direction to good outlets to get the most of what you already have.
Cheers, Trevor.
AnswerID: 304222
Follow Up By: timbo2 - Saturday, May 17, 2008 at 07:19
thx were on sunny coast, who do you recomend? apparently beaudesert exaust are good for the 3"exaus t and drop pipe.apparently changing the annoid helps as well any sugggestions appreciated.
FollowupID: 570340
Follow Up By: Trevor R (QLD) - Saturday, May 17, 2008 at 12:48
Timbo2,
Beaudesert do a good pipe (I have one) but a mate of mine got same 3" pipe from Rob Bliss Exhaust at Robinson Rd Geebung for $300 cheaper so I would try them as well. Whoever you get the exhaust from make sure you get the dump pipe from the turbo at the same time.
Tune up, I would highly reccomend Mike Vine Turbo's at Capalaba. He squeezed more from mine than anybody else has been able to.
If you want to come for a run in mine when you are down in Brissy to see what they can go like, I would be only too happy to do so. May take a while for us to get together as I am away for work a bit and the truck is always with me on the road, but if time is suitable we can arrange something.
Regards, Trevor.
FollowupID: 570401
Follow Up By: timbo2 - Saturday, May 17, 2008 at 17:20
thanks for that Trevor.will call gebung.what part of brissy you in?
FollowupID: 570441
Follow Up By: Trevor R (QLD) - Saturday, May 17, 2008 at 17:30
Virginia, 3 mins drive from Rob Bliss Exhaust.
email me at dieseldrifter at bigpond dot com
Cheers, Trevor.
FollowupID: 570446
Reply By: 98Jack - Friday, May 16, 2008 at 21:52
Hey Timbo2,
I've now got a 99 TD42T (Non intercooled). Ours was running like a slug since we got it, but didn't really realise as it was the first patrol we'd owned. Wife pulled up beside our twin a few weeks back (well it looked identical to ours) and when the lights went green, the wife was left at the lights as if she hadn't accelerated at all.
So we got ours tuned a bit, had the turbo boost adjusted and the injectors cleaned and adjusted (not completely replaced yet though) and it has made a very noticeble difference in acceleration and general driving.
I'd suggest before you go spendimg thousands on turbo mods etc, get it looked at by a diesel mechanic as your injectors might need replaceing or adjusting along with fuel pump and turbo boost setting.
Yes, I'll be getting a 3" pipe installed and injectors repalced in the next 12mnths, but the $350 spent on small adjustments has been well worth it.
AnswerID: 304229
Follow Up By: timbo2 - Saturday, May 17, 2008 at 07:22
thx, my old 4 cyl diesel nissan had more grunt, i cant use 2nd low in the bush on hills
FollowupID: 570343
Reply By: Member - Ed. C. (QLD) - Friday, May 16, 2008 at 22:29
Ummm, at the risk of stating the obvious, have you checked your air filter lately?? If it's gutless and using too much fuel, that's the first place I'd look...
Also, some (but apparently not all) TD42's have a gauze strainer in the fuel pump (under the inlet pipe banjo bolt).. doesn't take much gunk in there to restrict fuel flow, and that'll make it pretty gutless also.. take this out (if fitted) and blow it out with compressed air (don't lose the spring!)... Might like to change your (main) fuel filter while you're at it;-)
Check the simple things first, I say;-))
Confucius say.....
AnswerID: 304241
Follow Up By: timbo2 - Saturday, May 17, 2008 at 07:24
ummm yep, its been this way since purchase, this is my first 4.2.i wull check the gauze strainer.thanks
FollowupID: 570344
Reply By: rumpig - Saturday, May 17, 2008 at 08:11
can definately recommend Beaudesert exhausts for a 3" system. only problem is they don't open on saturdays (unless that has changed in the last 5 months), so it will need to be a mid week day trip for you.
i was abit disappointed with my turbo add on to my 1HZ cruiser, didn't have the power i expected (was still running factory system for a couple of days). that was until the 3" exhaust system was done, made a huge difference to the vehicle.
they are about $300 dearer then other places that do 3" systems, but i reckon they're worth it. the place is by no means a small country town workshop, it's bigger then most brisbane exhaust shops and has some pretty impressive machinery there aswell.
AnswerID: 304283
Follow Up By: timbo2 - Saturday, May 17, 2008 at 11:48
thx, will make a visit to them,do you know who could dyno it or tune it after the exaust installed(around brissy)
FollowupID: 570388
Reply By: Simon V - Saturday, May 17, 2008 at 09:30
It might pay to check the gauze filter at the banjo bolt on the fuel pump if the filter is dirty it will cause a loss of performance
AnswerID: 304291
Follow Up By: timbo2 - Saturday, May 17, 2008 at 17:21
whre on the pump is the banjo bolt?thx
FollowupID: 570442
Reply By: Member - John - Saturday, May 17, 2008 at 12:56
timbo, give MTQ in Toowoomba a ring, talk to them about turbo mods etc, they know there stuff. More than happy, have driven from Victoria twice to have them mod my Nissan.
John and Jan
AnswerID: 304320
Follow Up By: timbo2 - Saturday, May 17, 2008 at 17:24
Hi John, thanks for the info
FollowupID: 570444
Reply By: Member - 120scruiser (NSW) - Saturday, May 17, 2008 at 16:20
My opinion is you can have a 4.2 that is a slug but will go for ever or a 3.0 which goes like a shower of s*&t but will not last very long. I know what I would have.
AnswerID: 304338
Follow Up By: timbo2 - Saturday, May 17, 2008 at 17:23
yer true, but my mates stocko non turbo 4.2 has more grunt
FollowupID: 570443
Reply By: kym111 - Monday, May 19, 2008 at 23:29
Hi Timbo2
Just wondering, how have you driven the vehicle whilst you've had it? I'm a big believer in running engines in properly. Our 2004 4.24td Patrol was and still is a slug, but getting better. Mind you, I'm used to driving a V6 Camry...
The Patrol had done 40,000kms when we got it about 12 mths ago, and couldn't beat a snail off at the lights. AFter driving it like a racing car all the time, it's on the improve. Still not as good as the Camry, of course, but I'm getting used to it....
Drive it gentle, and it will be gutless; run it in hard and it will be a good vehicle!
AnswerID: 304791
