New GU with 285/70/17's hitting mud flap
Submitted: Tuesday, May 20, 2008 at 13:42
DARREN
Picked up my new GU yesterday with Cooper ST's in the above size and see the front mud flaps will have to go cause one tyre scrubs on full lock. PITA as I am keen on the flaps for stone deflection in particular. Any suggestions?
Reply By: ingo57 - Tuesday, May 20, 2008 at 15:16
Darren
Easy fixed, remove the inside screw and relocate the back end of the mudflap on the other side of the bracket space it out with a couple of nuts and put a small bolt and lock nut through it.
You will also need to cut a little section out of the inside of the mud flap in order to put a bolt through. Try it and you will see what I mean. I have BFG 285/70/17 and they don't rub anymore, If you get stuck I can email you a pic if needed. Hope this helps
304867
Follow Up By: DARREN - Monday, May 26, 2008 at 17:07
Hey ingo, did as you suggested and it worked a treat, mind you less than 10mm clearance on lock so could be a problem in the mud but overall very happy with the solution.
572008
Reply By: Member - Mick O (VIC) - Tuesday, May 20, 2008 at 15:42
I was just pricing some new tyres today and was told that to fit the 285's properly, the car required a lift kit. As
mine has a 2" lift, I was OK. That was a 285 75 16 which would be near the same size as yours with the 285 70 17.
Cheers. Mick
304872
Follow Up By: DARREN - Tuesday, May 20, 2008 at 17:18
thanks Mick, yeah my other GU with 285/75/16's and a 2 inch lift had no dramas
570921
Follow Up By: Waynepd (NSW) - Tuesday, May 20, 2008 at 21:05
same deal here a 2" lift and no probs with clearance
570966
Reply By: Peter McG (Member, Melbourne) - Tuesday, May 20, 2008 at 15:54
For trips I use 285x75x16 Goodyear MTRs on ROH steel
wheels. I have removed the original mudflaps because they scrub the tyre and have fitted a trimmed standard mudflap. Looks OK and helps keep the mud off the car. You might find that you need to trim the rear arch above the tyre as
304875
Reply By: VH-GU4 - Tuesday, May 20, 2008 at 16:45
Instal a 12.5mm radius arm spacer from BBMotorsports. 02 9679 9744. Cost is $50 + P/H
304884
Reply By: DARREN - Tuesday, May 20, 2008 at 17:21
that's gold thanks guys, might try ingo's suggestion as it seems the simplest - I'll have a look and may come back to you for a pic.
304894
Reply By: Visitor - Tuesday, May 20, 2008 at 22:41
I sliced my mudflaps down the middle
304981
