centre diff lock
Submitted: Friday, May 23, 2008 at 14:21
ThreadID: 57916 Views:2670 Replies:4 FollowUps:5
gday all i am installing a diff into my 93 80s landcruiser the diff is out of a base model i have to lock the hubs in myself i know i have to engage the centre diff lock in to make it move is that going to harm it in any way being engaged full time ?
i know the front diff will still spin it will just run off rear wheels which is what i want i have tried to get a free wheeling hub kit but they only make them for 91 and 92 models is that true thatnks for taking the time to read this.
Regards Troy.
Reply By: bennspoon - Friday, May 23, 2008 at 14:58
Shouldnt do any harm having the front hubs locked in all the time- Theres nothing that will be weaker and more likely to break because of it. Dont expect any fuel economy difference for as long as you are driving that front diff. The backlash should improve out of sight though.
Free wheeling hub kits are available for all years- As far as I know the 91/92 just had smaller front discs, no change in the hubs that I know of. All years RVs and base models had free wheeling hubs so Id be surprised if ya couldnt get them. 60 series hubs are popular for the conversion.
With the t-case, Marks do an adaptor for about $600 that changes the diff to a solid drive so you can cut out the drive to the front diff easily. Had a mate that bolted one it- pretty straightforward if you are good with spanners.
AnswerID: 305460
Follow Up By: Troyz80s - Friday, May 23, 2008 at 16:09
Thankyou very much benn so i can leave the diff im putting in and then buy the adaptor from marks in melbourne later? and install it myself. thanks again mate im not going to leave the front hubs locked in im just going to lock the centre lock diff up and just put up with the light un till i get that adaptor take care mate.
Regards Troy
FollowupID: 571478
Reply By: Member - Doug T (FNQ) - Friday, May 23, 2008 at 20:00
I don't think you have a clue as to what your on about.
AnswerID: 305509
Follow Up By: Troyz80s - Friday, May 23, 2008 at 23:00
probably not doug but at least im having a go and i cant afford a mechanic so i dont have a choice but thanks for your in put
FollowupID: 571576
Follow Up By: Member - Doug T (FNQ) - Saturday, May 24, 2008 at 05:47
Troyz80s
I'll explain a little more then. why would you fit free wheel hubs and then keep them locked, that defeats the purpose,as for the center diff lock all that does when engaged is makes the vehicle like any basic 4x4, It's main function is to reduce windup in constant 4 wheel drive vehicles on hard surfaces , when engaged it has no effect on aiding the vehicle in a bogged situation anymore than any other standard 4x4,
On saying that I give you credit for having a go , a good way to learn and you sure do save money , in a lot of minor repairs the labor costs are much more than the part,
FollowupID: 571585
Follow Up By: Troyz80s - Saturday, May 24, 2008 at 07:40
thats true doug im only buying the free wheel front diff off an base or rv model because i have to replace the original diff so i thought well ill buy that one then get the adaptor later on for the transfer case to make it a legit part time 4x4.
but if i keep them unlocked untill i do get the adaptor, i will have to engage the centre diff lock to make the car move. have you ever tried to move an 80s full time 4 wheel drive when the front tail shaft is out or the rear, you wont go far. untill you lock it in.
regards troy
FollowupID: 571595
Reply By: ozwasp - Saturday, May 24, 2008 at 06:55
Have a read of this link:
diff locks
AnswerID: 305556
Follow Up By: Troyz80s - Saturday, May 24, 2008 at 07:41
thatnks ozwasp very informative take care mate.
Regards Troy
FollowupID: 571596
Reply By: Wayne's 60 - Saturday, May 24, 2008 at 15:25
Hi Troy,
This site has very good information.
Wayne.
AnswerID: 305607
