Overlander 700 bettery
Submitted: Thursday, Jul 03, 2003 at 19:14
ThreadID: 5795 Views:2709 Replies:5 FollowUps:3
I've got an Overlander 700 battery that I've been using for 6 years as a cranker
in a diesel troopy and had no problems with it at all. Now on cold mornings it is
getting a bit sluggish so I'm replacing it with another one of the same type
because I reckon their a good thing, I'm also sticking a 10,000lb warn on the front
that will get occasional use short use, I think they will work well together but am just after some feed back.
Reply By: Phil R- Thursday, Jul 03, 2003 at 19:19
Oops that's BATTERY not BETTERY, I'm not from NZ.
AnswerID: 24124
Follow Up By: Steve from Drive Systems Victoria - Thursday, Jul 03, 2003 at 21:28
Would be even better if you had two of them, switched in parallel when winching.
FollowupID: 16239
Follow Up By: KiwiAngler - Thursday, Jul 03, 2003 at 21:29
Do you really THEENK you are not from NZ :-)
FollowupID: 16240
Reply By: Member - Topcat - Thursday, Jul 03, 2003 at 21:31
Hi Phil, I'm also running the same battery in my troopy & it's been in for 3 years service so far without any cranking problems (6.5 Chevy diesel); so if I get the life out of it as you have I will certainly get my monies worth. Would be interested to so what a capacity test on your old battery gives. As for winching I run an X9 superwinch & there doesn't seem to be any problems in battery drain with mine. I keep the donk ticking over when winching in any case.
Cheers.Have Wheels Will Travel
AnswerID: 24137
Follow Up By: Phil R - Thursday, Jul 03, 2003 at 21:56
I haven't had it tested but I might do it as it might be ok to run fridge or
parallel with new one for winch as Steve suggested. I'll look into that ...
FollowupID: 16244
Reply By: Truckster (Vic) - Thursday, Jul 03, 2003 at 23:41
Yup, I have one in my car too, very good so far 2yrs out of it.
Just put in an exide extreme as the second battery, going to run accessories and fridge off that, and the winch off the main.
Piranha Dualbattery kit.
AnswerID: 24160
Reply By: Member - Sam (NSW) - Friday, Jul 04, 2003 at 09:44
I had one put in my Hilux last year when the old one started to show signs of packing it in, and when I installed the dual battery system, I also put an Overlander 700 in for the second battery (my needs didn't require me to purchase a deep cycle). Fantastic battery. Not one problem so far and they have handled the corrugations i've put them through (have heard stories of other batteries falling appart due to excesive vibration).
cheers,
Sam.
AnswerID: 24176
Reply By: Member - Willem- Friday, Jul 04, 2003 at 11:03
Yep, I have had a Century/Yuasa Overlander 700 for 5 years now. About 12 months ago I bouight a Desert King 17 plater and transferred the Overlander to the Auxilliary position. Both batteries work a treat. Will replace Overlander weith another one when the time comes.Cheers, Willem
Never a dull moment
AnswerID: 24181
