Water tanks
Submitted: Thursday, Jul 03, 2003 at 22:48
Member - Cocka
Good news to pass on. I cannot see that these tanks have been mentioned on the
forum before so thought I'd stick a post in the data base.
I've been looking for suitable means to carry extra
water for those occasional remote trips when you've gotta have that extra. The cost of S/S tanks I thought rediculous on a $ / litre basis, + permanent additional weight, underfloor hard to flush and have to be pressurised to be efficient. Also act as additional flotation in deep
water crossings if not filled.
Then there are metal jerry cans which can be racked on the back or on roof. On the roof tanks need only be filled only at the last top up stop & need to be emptied first to reduce top weight, these should be really
well secured.
The blue plastic jerry-can type bottles are great because they are light and cheap, again only need to fill to your requirements at the last top up stop. If carried on top put carpet or like under bottle to save damage. They are easily carried inside because they are soft and light.
Flexible (collapsible)
water tanks fitted inside down low can be built into a retaining frame and hold large quantities in awkward areas, but line area with old carpet to prevent abrasions, they are only gravity feed outlet.
Now here's the good bit. I had a look at a particular 4x4 brand 55 litre that sold for $211 & an 85 Lt that was $293 & thought that a bit exy.
However found a 100 Lt flexy for $109.oo. Now thats a lot of
water but you don't have to fill it up. It can be stored on top as the
tank is inside an outer protective UV cover, strong tie down points & excellent quality.
The suppliers are Whitworths Marine and there are a range of sizes. The brand is
Turtle-pac. They also make flexi
fuel tanks. Check WWW.
My view is that they are light and easy to store when not in use & cheap.
Reply By: Truckster (Vic) - Thursday, Jul 03, 2003 at 23:12
That url again for the blind would be ???? www.
24157
Follow Up By: Member - Cocka - Thursday, Jul 03, 2003 at 23:19
For the frail, infirmed and visually impaired and Truckster -
www.turtlepac.comCarpe Diem
16252
Follow Up By: Truckster (Vic) - Thursday, Jul 03, 2003 at 23:21
I'll swap
places, I'm sittin her with wife who had her 4 wisdoms out 6pm last night, and since then I cant put a foot right!
16253
Reply By: daren - Thursday, Jul 03, 2003 at 23:17
and if you go there this weekend in
Melbourne, they have 15% off everything. its in response to the boat show that on at the moment.
24159
Follow Up By: Member- Rox - Friday, Jul 04, 2003 at 01:14
Daren , who got them on special? turtal pac or whitworths? Around Oz 06/2004
16258
Reply By: Member- Rox - Friday, Jul 04, 2003 at 01:17
Cocka, Do you have an address for Whitworths Marine, also ph. e mail, www.
Have looked at www.turtelpac.comAround Oz 06/2004
24164
Follow Up By: joc45 - Friday, Jul 04, 2003 at 07:30
Rox,
check out www.whitworths.com.au
All will be answered there.....
Gerry
16262
Reply By: Member - DOZER- Friday, Jul 04, 2003 at 09:25
Hi Checkout www.motorcare.com.au, and look under watertanks. They sell collapsable tanks that fit in the rear quarter panel.
Andrewwheredayathinkwer mike?
24173
Follow Up By: joc45 - Friday, Jul 04, 2003 at 14:54
A friend had these fitted into the side panels of his L/C 100 series. After a few rough roads, the inside panels started to bulge out from the pressure of the
water sacs. Certainly looked strange! Don't know if they were the same brand as above. Great idea otherwise.
Gerry
16277
Reply By: Member - Cocka - Friday, Jul 04, 2003 at 09:37
Yeah that's right Joc, thanks for that. I hope some of these blokes drive their 4x4 and navigate better than they drive a computer.
Repeating :
http://www.whitworths.com.au/customer_service.asp?ID=102&pg=112
(specials) :
http://www.whitworths.com.au/main_specials.asp
There is no
Turtle-pac pic in the [Whitworths] online catalogue. You can
sign up free for their mail order catalogue.
They have a huge range of gear, mostly marine oriented, but if it suits the salt & sun it'll suit the scrub.
They have a good mail order system - I'm lucky as there is one store 5 min from home.
But also view the
Turtle-pac site for their range of products but buy through Whitworths.
I should be on a commission for this crowd.
24175
Follow Up By: Bob Y. - Qld - Friday, Jul 04, 2003 at 20:13
Bit late for the commision, Cocka, I've been pushing Whitworths for different items on this site, for nearly 12 months. Still to receive first cheque :-)
16303
Follow Up By: Member- Rox - Friday, Jul 04, 2003 at 22:45
Cocka, Still carnt see them. were on the site are they?Around Oz 06/2004
16313
Follow Up By: Member - Cocka - Saturday, Jul 05, 2003 at 00:58
Geez Rox I don't know how to tell you.
If you copy then paste the above address' I have given then you should see what we are talking about. If that doesn't work just do a Google search for Whitworths Marine and
Turtle-pac.
Best of luck.Carpe Diem
16317
