80series driver window switch
Submitted: Saturday, Jul 05, 2003 at 12:38
Bat
I need a switch for the front window driver side .toyota part $400 are there any cheaper ways.Bat
Reply By: diamond (bendigo) - Saturday, Jul 05, 2003 at 14:12
the problem with a lot(not sure about cruiser)is they get a lot of dirt ect in the switch.
did it on my camry and ghia drivers side front.
pulled switch out and pulled it a part cleaned it up and if i remeber right the camry one needed a little playing around with the contacts.
pull the switch set up out of the door the actual toggle switch should unclip and clean all the junk out.
and if you brake it worse you already have to buy a new one.
so nothing to lose.
good luck.new job coming so no fraser this time:-((
24265
Reply By: Member - DOZER- Saturday, Jul 05, 2003 at 21:18
Hi Bat, i have a spare if you need it, but then i may need it ....
You can pull them appart and clean them, depends if it has blown up from resistance or just failed due to dirty contacts.
Email me on limo4b@yahoo.com.au if you want to get more info on how to clean them
Andrew wheredayathinkwer mike?
24287
Reply By: Member - Howard- Sunday, Jul 06, 2003 at 20:41
Bat,
the driver side front switch on my 93 GXL sh*t itself a few weeks ago . Would go down but not up, when I looked at master switch assembly the contacts for that window were all brown and burnt.
Not willing to part with $400 I just swapped over the wires in the plug so I now use the drivers side rear window switch for the front window.(only the fridge sits on rhr
seat anyway. make sure you disconnect plug to rear window at rear door.
works for me.
Howard
24354
Reply By: Member - Glenn(VIC) - Monday, Jul 07, 2003 at 09:39
Are you positive it is the switch?
I have just replaced my front drivers side window motor and regulator as the window had stopped functioning. At first I had been told by my mechanic that it was the switch as he couldn't hear the motor working, but after pulling the door apart and having a look I found the fly wheel on the window motor was screwed. Toyota wanted $460 just for the motor, but after ringing a lot of wreckers, Hall 4 x 4 Salvage in Bayswater had a couple in stock for $110.00. The part was clean and it even included the regulator that had been re-greased.
Hall 4 x 4 Salvage can be contacted on:
03 9729 7566
email ra.hall@bigpond.com.au
www.hall4x4salvage.com.auJust Do It!
24385
Reply By: Member - DOZER- Tuesday, Jul 08, 2003 at 19:06
Hi Guys
If you need a new switch block i have a spare that will be cheapish. Might aswell turn it into cash and hope
mine stays ok.
24502
