Diesel turns over but won't run
Submitted: Sunday, Jun 01, 2008 at 18:30
GoneTroppo Member (FNQ)
Ok this is about a tractor so it's slightly OT, but it is a 4wd one so that counts.
This is a Fiat/NewHolland 80hp tractor with a 3.9l Iveco normally aspirated 4 cyl motor. No electronics no computers no nothing.
Normally it just runs and does it's thing, reliability personified (or should that be tractorfied)
Yesterday went to start it, tuns over but no start, normally it starts instantly. Plenty of juice in the battery, plenty of
fuel at the injector pump, cracked open an injector pipe, plenty of
fuel.
Fiddled at bit more, suddenly it roars to life. OK who knows.
Drive off. then 150meters later it dies again that's when I noticed that the lights on the dash were off.
Still cranks OK but no go.
So it's an electrical thing but what?
God I hate auto electrics!!!
Secondly I always thought that these simple motors just kept running once they were lit so long as there was
fuel?
Any ideas as to where I start looking would be much appreciated.
Reply By: Member - Axle - Sunday, Jun 01, 2008 at 18:43
Normally to stop the motor do you just turn the key,( Ignition off?) If so it could be the solenide shut off on the pump, Maybe?
Hate electrics also. Good luck!
Cheers Axle.
307182
Reply By: autosparky - Sunday, Jun 01, 2008 at 19:30
corroded ign or fuselink
307197
Reply By: Member - DOZER- Sunday, Jun 01, 2008 at 22:03
Agree
Has it been raining lately?? My xray vision is on the fuse for the dash, or ignition switch contacts which also i am guessing supplies power to the
fuel cut off on the pump...sought the loss of volts and you will have a happy tractor motor again.
Andrew
307252
Reply By: trouper - Monday, Jun 02, 2008 at 14:18
Agree with the others...... check
fuel cutout switch or power to it
regards
307327
