PROTECTIVE SLEEVE - over Dynamic Rope
Submitted: Sunday, Jun 01, 2008 at 19:44
KiwiAngler
Greetings
I want to put a length (about 12 -15mtrs) of the
orange protective sleeving over the first 12- 15mytrs of my dynamic rope winch cable.
This will serve 2 purposes:
1) it will mean that the first layer (about 22 turns) of the dynamic rope will have a cover thus improvong it's resistance to UV while on the winch and
2) I can slide the protective cover down if the rope has to go over any rough or rocky areas whilst winching and it would then act as an anti-abrasion for the dynamic rope
I know a numbe rof $x4 outlets (ARB and TJM) sell it in 2 mtre legths but I am looking for 1 unbroken length about 1 2-15mtrs long
I have read about others doing this but haven't found a supplier yet
any ideas who I could get this from is appreciated
Reply By: pradowolf - Sunday, Jun 01, 2008 at 21:04
contact Roger from beadlock Australia , he will have the stuff but it will take a lot of space on your winch.
307232
Follow Up By: KiwiAngler - Sunday, Jun 01, 2008 at 21:08
pradowolf
Why do you say 'it will take a lot of space on your winch"?
573096
Reply By: pradowolf - Sunday, Jun 01, 2008 at 21:25
because it will make the rope thicker and will reduce the amount of meters that you can spool on to the drum.
Ask Roger from Beadlock , he can give you the answers. he imports the Dynamica rope through me.
307236
Reply By: Member - Bradley- Sunday, Jun 01, 2008 at 22:30
I have done exactly this and found it works
well, although you do have to be a bit carefull with the last layer on the drum as the sheath packs it out fairly quickly.
I just used about 2 meters of inch and a half
grey layflat hose from the irrigation suppliers. cost me $10 from memory.
307258
Follow Up By: KiwiAngler - Monday, Jun 02, 2008 at 16:53
I already have a couple of meters covering the layer that goes om the drum
I am now looking to cover the layer that is the topmost layer on the drum
I calculate that about 12-15mters (22-24 turns around the drum)
The
grey layflat hose - is it made of woven fibreglass fabric or plastic?
573215
Follow Up By: Member - Bradley- Monday, Jun 02, 2008 at 21:00
Its a woven nylon coated with a vinyl type of ruberised material. hope that makes sense.
Mine is
water hose but you can get all different types -
fuel resistant / high temp etc etc.
You must have one damn big winch drum!!
Mine is packed solid to the brace rods. Although there is a lot of plasma on there to begin with.
573240
