94 nissan patrol petrol install TD42 diesel
Submitted: Sunday, Jul 06, 2003 at 10:52
robert4615
anyone have and info on the diff ratios on the 94 patrols, are they the same or do they differ? what ratios do they run? will the bellhousing on the TD42 diesel bolt up to the 5 speed trans on the petrol engine? is this a fairly easy swap? any ideas, has anyone done this swap? any help will be appreciated. regards
Reply By: Truckster (Vic) - Sunday, Jul 06, 2003 at 22:58
The diff ratios are marked on your compliance plate...
should see
HG39 3.9's
HG41 4.1's
HG43 4.3's
HG46 (I'll fight ya for em! RARE...)
The bell housings are different...
the man to talk to is Pete Christie on the Patrol4wd group, he knows this stuff backwards.
24369
Reply By: Mick - Monday, Jul 07, 2003 at 09:11
Hi this is mick christie.
A td42 will fit in, wiring loom is a b#*ch the bellhousing has to get a bolt hole drilled and tapped for the starter motor, thers is a position for it but nissan never did it chasis mounts have to be changed. Ring us on 02 9620 1208 fore more details
24383
Reply By: Steve from Drive Systems Victoria - Monday, Jul 07, 2003 at 20:52
1994 TB42's ran with 3.9:1 and the TD42 had 4.1:1. Minor difference with the bellhousing(as above link), but will bolt to gearbox.Engine mounts are same.
24424
