Urgent Auto Electrics Question Please.
Submitted: Friday, Jun 13, 2008 at 17:36
ThreadID: 58722 Views:2645 Replies:6 FollowUps:1
I have a 100 series TD 2000 model with an altrernator that has gone bang, will an alternator off a 100 series 1HZ engine fit, does it have the same amp output, will it work ???
I need facts, as I can change one over the one from the spare car tonight, and get another one sent from Darwin tomorrow to fix the spare car.
Thanks in advance.
Cheers Steve. electrics
Reply By: Peter 2 - Friday, Jun 13, 2008 at 18:24
Steve would be ebstto ascertain why it went boom and how badly as they are rebuildable up to a point
AnswerID: 309716
Reply By: Member - Phil G (SA) - Friday, Jun 13, 2008 at 18:36
Steve,
I'd be 90% sure that it will fit. They were all 110amp and internally regulated, so theres no issues with it working. They all have the 2A pulley. Only issue I was aware of is that some have a round wiring plug, and others have an oval plug - I'd guess that both of yours are oval. So I'd be doing it.
Also, its very easy to swap the regulator unit and brushes in those alternators.
phil
AnswerID: 309719
Reply By: Affordable Batteries & Radiators - Friday, Jun 13, 2008 at 19:41
Why not just drive the spare car and repair the TD ?
AnswerID: 309739
Follow Up By: Top End Explorer Tours - Friday, Jun 13, 2008 at 19:48
The spare car is a spare car for reason.
Cheers Steve.
FollowupID: 575683
Reply By: TD100 - Friday, Jun 13, 2008 at 21:21
how many kms has it done now steve? i know once they hit about the 100k mark and have done some swimming and mud bathing they do chop out brushes. as for the bang ? Paul
AnswerID: 309769
Reply By: autosparky - Friday, Jun 13, 2008 at 21:47
the t/d alt may have a different plug to the regulator, to the 1hz motor . the mounting should be the same , the t/d may have computor driven field control(regulator) if both have flat plug , and terminals are i a l then should be compatible, but if 1 is or has 4 pins and c or d is on pin cofig then they wont be .
AnswerID: 309777
Reply By: Top End Explorer Tours - Saturday, Jun 14, 2008 at 10:15
To those that tried to help thank you.
I was able to contact my parts supplier this morning and they are the same alternator.
Cheers Steve.
AnswerID: 309857
