Extension lead for TX3440
Submitted: Saturday, Jun 14, 2008 at 20:30
ThreadID: 58784 Views:3039 Replies:3 FollowUps:3
Hi all,
I may need to extend the microphone lead on the TX3440. Has anyone done this and if so what parts are needed?
Reply By: Member - Ed. C. (QLD) - Saturday, Jun 14, 2008 at 21:09
Dunno if this onemicrophone extension lead will do the job, but I guess ya could contact the dealer & find out;-)
Confucius say.....
AnswerID: 309999
Reply By: PeteS - Saturday, Jun 14, 2008 at 22:01
G'day Avan
Yep the lead Ed suggests should do it. It's just a 4 pair data cable (Cat5 will do) with an 8 pin RJ socket one end and 8 pin RJ plug the other.
The TX3440 comes with the curly cord and an extension piece. I assume that extension piece is too short? A cheaper alternative would be to use the 8 pin joiner they supply with the 3440 and buy an 8 pin computer patch lead (blue) to the length you want. Hope I make sense?
PeteS
AnswerID: 310007
Follow Up By: Boobook2 - Sunday, Jun 15, 2008 at 08:32
It is pretty dificult to get RJ Sockets for cables, Plug to plug with a F-F joiner is probably the go. Also pre-wired RJ 45 to RJ 45 are almost certainly going to be wired for Ethernet pinouts ( they are not 1 to 1). This may or may not work depending on the wiring for GME.
FollowupID: 576040
Reply By: oldpop - Sunday, Jun 15, 2008 at 07:41
Hello
does the tx3440 have a speaker in the hand piece
regards
Oldpop
AnswerID: 310031
Follow Up By: PeteS - Sunday, Jun 15, 2008 at 08:34
Hi oldpop
The GME TX3440 does not have the speaker in the handpiece, it is in the UHF body as is normal for most UHFs.
The 3440 has all the controls on the handsets as per photo below
PeteS
Image Could Not Be Found
FollowupID: 576041
Follow Up By: oldpop - Sunday, Jun 15, 2008 at 08:37
Thanks for that Pete
Oldpop
FollowupID: 576043
