New motor landcruiser
Submitted: Tuesday, Jul 08, 2003 at 17:39
ThreadID: 5880 Views:2000 Replies:5 FollowUps:0
Hi guys,
the head has gone again on my 89 GXL crusier (3F motor 5 speed)
and i was wondering what to do. I don't want to spend another $1000 on the head again. So i was looking at putting a V8 in. Is it a good idea or would i be better off just getting a change over engine? we travel up north a bit towing a camper van, so i thought the V8 would be the go because it would the crusier a bit more grunt. currently i runnig on dual fuel and want to stay that way, due to the lack of gas up the middle of oz. hope someone can point me in the right direction
Thanks Deano
Reply By: Member - DOZER- Tuesday, Jul 08, 2003 at 18:41
Deno, i have a 3f in an 80 series that is going cheap, has extractors.
You can test drive it aswell as what ever other test you like:-)
You will probably find the inlet manifold to blame on yours, or a warped flange is leaking, or the jetting in the carbi is too lean.
The 80 3f has a lighter flywheel, and a heat exchanger on the oil aswell, and doesnt seem to have the valve problems the earlier 3f's did. All fits thesame as yours, no mods.
If you want to go v8, it will cost you 1500 for the kit, then 500+ for the engineers report, exhaust, power steer brackets etc, so my advice is to stick with the boat anchor.
I am able to pull out and also deliver (within reason) Give me a bell on limo4b@yahoo.com.au
Andrew
wheredayathinkwer mike?
AnswerID: 24494
Reply By: Member - Robert (WA) - Tuesday, Jul 08, 2003 at 18:52
WHAT HAPPEND TO THE HEAD
AnswerID: 24498
Reply By: bluehealer - Tuesday, Jul 08, 2003 at 20:23
try a can of chem i weld or kem e weld not sure how to spell ,buy at local servo or spare parts shop,put in radiator ,follow instrutions carefully,works wonders on cracked heads and leaky head gaskets,
AnswerID: 24505
Reply By: Martyn (WA) - Tuesday, Jul 08, 2003 at 21:42
Deano,
I'll second that what happened to the head? Why has it gone again?? Just interested...........Keep the shiny side up
AnswerID: 24510
Reply By: Member - DOZER- Wednesday, Jul 09, 2003 at 17:16
Sorry Guys
Sorry for putting myself first there, i presumed it was valve seats because of the 3f and LPG. As you rightly point out, it could be anything from leaking coolant to a stripped thread in the plughole...
Andrew wheredayathinkwer mike?
AnswerID: 24557
