leaking 100 series ?roofracks maybe?
Submitted: Monday, Jun 23, 2008 at 22:03
Member -Toonfish
recently took off my rear rack to get in my brothers shed for repairs and on the weekend noticed
water in the bottom near the tailgate where the rear bodymounts are located?
have heard about roofracks somewhere here i think do most people silastic the bars in place as
well?
Reply By: Vivid Adventures - Monday, Jun 23, 2008 at 22:13
Yep leaking through the bolt-holes and mounts...
311909
Follow Up By: Richard W (NSW) - Monday, Jun 23, 2008 at 22:51
Agree.
I had a leak and reseated the bolts with Silastic.
577889
Follow Up By: Member - Andrew (WA) - Monday, Jun 23, 2008 at 22:52
You mean these 100's will take
water through the roof racks factory pre-positioned holes in the roof?
What stops the
water entry when you don't have a rack? and why the hell do they leak in the 1st place...surely the holes don't go all the way into body (cabin) without a
water proof stop????
577890
Follow Up By: Vivid Adventures - Monday, Jun 23, 2008 at 23:38
yes - 100s do take
water through the factory installed mounting points. They come with (presumably sealed) bolts in place "filling" the holes.
The holes presumably go into the body without a
water proof stop but I've not taken it apart, not looking inside.
I had this problem - when I asked numerous folks told me they had had the problem, and their solution worked. Since then I have had opportunity to help half a dozen others with the news.
577899
Follow Up By: MEMBER - Darian (SA) - Tuesday, Jun 24, 2008 at 10:00
Andrew - the vehicle comes from the factory with a soft, plastic waterproof seal over the roof rack mounting flanges - needs to be picked out to do a roof rack install.
577937
Follow Up By: Vivid Adventures - Tuesday, Jun 24, 2008 at 10:27
Not having seen one from the factory, I've yet to see that - thanks Darian.
Andrew.
577938
Follow Up By: Stephen M (NSW) - Tuesday, Jun 24, 2008 at 17:53
Happens on the 120 series prados as
well. Neighbour across the road has had all his hood lining replaced and front
seat due to it leaving
water marks, he wasnt a happy camper I can tell you. Toyota had to pull all the screws out and seal up then put back in. Regards steve M
577986
Reply By: autosparky - Monday, Jun 23, 2008 at 23:04
yes thats where its leaking from use sika flex or silastic around bolts
311915
Reply By: Member -Toonfish - Monday, Jun 23, 2008 at 23:25
thanks for the tardy replies
i thought this was the case as its only recent
will fix tommorow till my new rack comes in
311921
Follow Up By: Vivid Adventures - Monday, Jun 23, 2008 at 23:39
tardy... crikey! I took all of ten minutes.
577900
Reply By: Peter 2 - Monday, Jun 23, 2008 at 23:30
They also crack due to either too rigid a roof rack or too much weight on the rack (s).
Just need a bit more silicon then ;-))
311923
Reply By: Barry - Tuesday, Jun 24, 2008 at 09:45
I had this problem too, after Toyota fitted factory roof bars.
Problem also shows up with much worse symptoms if the 100 is parked nose downhill. First thing I knew was the passenger seatbelt was soaking wet. Seems
water had pooled in the bottom of the B-pillar and partially covered the retracted belt inside the pillar. On investigation, found
water in the front passenger footwell.
Took it back to Toyota who refitted the roof bars after sealing the rack hole threads with Silastic.
311959
Reply By: Featherfoot - Tuesday, Jun 24, 2008 at 12:29
I used pipe thread sealer out of a tube as opposed to sikaflex. Plumbers and aircon people use it to seal pipes under pressure so hopefully that works. Not as messy as sikaflex.
Gary
311988
Follow Up By: TD100 - Tuesday, Jun 24, 2008 at 18:47
yeah thats a better option, i used a bolt sealer that holden use on the manifold,
water pump and any bolt that goes in a
water jacket. never had a drama in 5.5 years. Paul
577997
Reply By: Member -Toonfish - Tuesday, Jun 24, 2008 at 19:17
yep bolt sealers it is then?
should have got a nissan???????????
312050
Follow Up By: TD100 - Tuesday, Jun 24, 2008 at 19:19
you may now go and wash your mouth out with battery acid !!!!!
578005
