hand winch (Big Haul)
Submitted: Tuesday, Jul 01, 2008 at 18:05
ThreadID: 59408 Views:2788 Replies:6 FollowUps:2
Greetings all
Would appreciate advice on how to get "clutch" handle on Big Haul into position. I can move it in right direction but cannot get it forward far enough to "lock". Therefore cannot insert cable. Is there a trick or am I just too weak in my old age. I have resisted the temptation to whack it with a lump of 4x2.
Appreciate any tips.
Regards Terry
Reply By: Member - Jack - Tuesday, Jul 01, 2008 at 18:40
Hi Terry.
Had the same problem when I first tried to hook up my Big Haul. Got help off this forum then. I have a User manual in .pdf format if that is of any use to you. I just need your email to send it to you.
Alternatively, I just tipped it up and pushed the "lock" thing and it moved quite easily. The clutch separated and the cable inserted easily. As they say in thye classics ... "easy when you know how".
Jack
AnswerID: 313303
Follow Up By: Bonz (Vic) - Tuesday, Jul 01, 2008 at 21:16
Jack, I wouldnt mind the instructions too please. bonzinc at iprimus dot com dot au please
FollowupID: 579396
Follow Up By: Member - Terry G (NSW) - Wednesday, Jul 02, 2008 at 18:25
Hello Jack
Sorry to be a nuisance but....
I tried the winch on most angles known to man but couldn't get any positive movement on the locking handle. Ignorance in this case is not bliss, at this stage its winch about 9 (bruises etc) and me nil.
Would like to know whether or not the handle actually "locks" up in some positive way or just moves across towards the levers in some undefined way.
Any advice appreciated. Hope my email address reached you, if not address on profile works Regards Terry
FollowupID: 579517
Reply By: Member - Terry G (NSW) - Tuesday, Jul 01, 2008 at 18:57
Thanks for the reply Jack. I think I have sent my email to you. Upside down it will be in the morning. Regards Terry
AnswerID: 313310
Reply By: Bonz (Vic) - Tuesday, Jul 01, 2008 at 21:13
yer I got one of them and they are hard to get the clutch to unlock, interested to jhear the tilt technique will have to remember that one
AnswerID: 313348
Reply By: Member - Bucky (VIC) - Wednesday, Jul 02, 2008 at 05:02
You are not on your own ...
Everyone I know that has one, including me, has had the same problem..
No real trick, just keep at it, and you will get it right !
Cheers Mate
Bucky
AnswerID: 313374
Reply By: Member - Terry G (NSW) - Wednesday, Jul 02, 2008 at 10:34
Thanks for the help everyone. I will persevere.
Regards Terry
AnswerID: 313399
Reply By: Member - Jack - Thursday, Jul 03, 2008 at 20:03
Hi all.
Following on from Terry G's initial posting, I did a video of how to get the clutch back on a Big Haul winch. I still have it, so if anyone wants a copy, email me at my hotmail address trav-eller @ hotmail . com ... ( omit the spaces in the address) and I will be more than happy to send off a copy. Alternatively, you can also get me through Member Messages.
jack
AnswerID: 313690
