Electronic Chips
Submitted: Saturday, Jul 05, 2008 at 16:22
exlorer
Has anyone fitted a chip to the current model Hi Lux diesel. If so what were the power improvements,would it make and difference towing and how about
fuel econmany.
Reply By: Member - Andrew J (VIC) - Saturday, Jul 05, 2008 at 16:41
Gooday, I haven't fitted one to a Hi Lux but recently fitted one to my Prado Turbo Diesel Auto, in ordinary driving I noticed little diff. but in towing my off road van ( nearly 2plus tonne it worked really
well, pulled
well and
fuel was in the 15eens, hope this help some
314010
Reply By: Trev (SA) - Saturday, Jul 05, 2008 at 16:48
If you get onto newhilux.net it has stacks of stuff about chips and heaps of other stuff.
I don't have a chip in
mine.
314012
Reply By: Member - Graham H (QLD) - Saturday, Jul 05, 2008 at 18:39
Havent done a Hilux but have just done my 2005 Cruiser TD
Also put a 3" mandrel bent exhaust which gave more power increase than the chip
Details below
Red = standard
Blue = with Safari Dtronic chip
Green= With both
Goes better, turbo comes in earlier, heaps more grunt and no black smoke when putting boot into it.
Remember the figures are power at the
wheels not the flywheel as quoted in mfrs specs
Image Could Not Be Found
314030
Follow Up By: Corio - Monday, Jul 07, 2008 at 11:53
GRaham,
Your graph shows exhaust and chip.I now have vehicle the same as yours.How much difference does just the 3 inch exhaust make as I dont want to fit a chip as yet or hadnt you tried them separately? Any info greatly appreciated.
580255
Follow Up By: Member - Graham H (QLD) - Monday, Jul 07, 2008 at 17:41
You can get an idea from the graph as to how much difference the exhaust makes Itallows it to spool up faster and stay up longer.
The reason I didnt do it on its own was it was too much mucking around as the guys were busy.
May get it done in a couple of months when they get their 4 wheel dyno.
The exhaust is a DTSMandrel bent 3" aluminised steel and cost allup with the dyno and fitting$1100
580294
Follow Up By: Corio - Monday, Jul 07, 2008 at 20:37
Thanks Graham
580318
Reply By: Corio - Saturday, Jul 05, 2008 at 19:41
explorer,
Fitted my 06 Hi Lux witha DP chip and sports exhaust.Makes a hell of adifference.Developed about 400 nm of torque compared to 343nm standard.Have been towing over two tonne with relative ease.Cost of chip is around $1200.Very easy to fit.Suggest that maybe the exhaust system should go hand in hand with the chip.
NOTE I beleive the Hi Lux October 06 onward has a different chip to the earlier model.
Fuel economy remained about the same.
314037
Follow Up By: Member - Graham H (QLD) - Saturday, Jul 05, 2008 at 20:13
Here is the link for the Safari Dtronic which I think is the better brand
http://www.safarisnorkel.com/dtronic/applications.htm
Go to applications as there are two for a 2006 hilux and you need to get the correct one
580101
Reply By: Stu-k - Saturday, Jul 05, 2008 at 21:45
There is a group buy going do soon on hilux.net for genuine toyota round 430nm and 145 kw, check it out
314053
Reply By: Member - Olcoolone (S.A) - Saturday, Jul 05, 2008 at 23:15
Have a DP chip in our 2005 Hilux and would not be with out it, better
fuel economy, driveability and more usable power.
We tow a 1400Kg Trak Shak and the Hilux weighs 2700Kg, we get about 13. Lts per 100k sitting on 110Kph.
314059
Reply By: DCTriton - Sunday, Jul 06, 2008 at 00:44
TDC Technologies The CRPlus is proving a big hit on the triton
forum - apparently available on ebay too
314064
Reply By: exlorer - Sunday, Jul 06, 2008 at 10:33
Thanks all my Hi Lux is the latter one with the increased power towing a 2 tonne off road van fuel not to bad towing 13.5l/100.
but a lot of gear changing on hills. I currently own a manual, but due to injury I need to buy auto when I can afford it .Is it the same chip for auto & manual.
314092
