volt meter for 2 batteries
Submitted: Sunday, Jul 06, 2008 at 16:24
Louie the fly
I can tackle most things, provided I have the correct information at hand. So, for my next trick, I want to install a volt meter for my main and axillary batteries so I can keep an eye on them. But I only want to put one gauge in. I presume it can be done, with a 3 way switch (or 2 switches may be safer), but how exactly should it be wired up. Can anyone help with a sketch or some info?
Reply By: Member - Nev (TAS) - Sunday, Jul 06, 2008 at 16:44
Reply By: Mike Harding - Sunday, Jul 06, 2008 at 17:41
I think this is what you are after:
Two batteries - one meter
Let me know if it's not.
Mike Harding
314132
Follow Up By: Louie the fly - Sunday, Jul 06, 2008 at 18:18
Thank you Mike Harding. Exactly what I'm after.
580173
Reply By: KiwiAngler - Sunday, Jul 06, 2008 at 17:45
What dual battery management system are you using?
If it is one of the newer Pirahnas
you can buy a Piranha dual battery monitoring gauge that plugs directly into the Pirahna system.
I have done this and put the guage inside the little compartment on the dash. The dual battery monitor is the small one to the left of the tyre sensor unit
314134
Follow Up By: Louie the fly - Sunday, Jul 06, 2008 at 18:20
I have the lo-tech solution, a Redarc isolator. Have used them in previous cars and always had good results.
580174
Follow Up By: KiwiAngler - Sunday, Jul 06, 2008 at 18:36
Louie the fly
And a Redarc tells you the voltage of each battery how?
580177
Follow Up By: Louie the fly - Sunday, Jul 06, 2008 at 18:59
It doesn't. Thats why I want to put a gauge in.
580182
Follow Up By: KiwiAngler - Sunday, Jul 06, 2008 at 19:06
Louie the fly
My sincerest apologies I didnt realise that you were the original poster - sorry mate should have scrolled back to the top before I posted my 'slightly' sarcastic reply
I have just given myself and uppercut :-)))
580184
Reply By: Member - Phil G (SA) - Sunday, Jul 06, 2008 at 18:21
Buy yourself a 3 position centre-off switch like this at any electronics
shop:
Have a wire from each battery go to the terminals at each end of the switch and connect the centre terminal to the voltmeter. Connect the voltmeter's earth to a suitable earthing point.
In the centre position, the voltmeter will turn off, which prevents it running the battery slowly down. I have a digital voltmeter in my cab that's hooked up this way.
314145
Follow Up By: Louie the fly - Sunday, Jul 06, 2008 at 18:34
Thats basically what the file Mike Harding directed me to shows, except it has a two position switch. I like the idea of the centre return switch though.
580176
Follow Up By: Member - Phil G (SA) - Sunday, Jul 06, 2008 at 19:19
All voltmeters use a small amount of current. LCD meters might only use say 8 milliamps, but LED and analogue meters use more. This won't matter overnight, and probably won't matter over a few days, but a voltmeter will run a battery down if left for a week or two. As my vehicle sits unused in the garage during the week, I like the 3-position switch so I can turn the meter off.
580186
Follow Up By: Mike Harding - Sunday, Jul 06, 2008 at 19:29
Without back lighting electronic meters, typically, have an input impedance of 10M which, at 12V, would draw 1.2uA which, in turn, would take the average car battery about 5000 years to discharge :)
Analogue meters are, typically, 20k per volt so a 15V meter would draw 40uA so we're still talking 150 years.
Mike Harding
580187
Follow Up By: Member - Phil G (SA) - Sunday, Jul 06, 2008 at 19:41
Mike,
Perhaps you could get a multimeter out and do some measurements.
My LCD meter with no backlighting was just measured at 7.3 milliamps.
I also measured an analogue meter (2" car meter with no backlighting) uses 87 milliamps. Thats 2Ah per day!!!!
I stand by what I said.
580191
Follow Up By: Mike Harding - Sunday, Jul 06, 2008 at 20:44
Hi Phil
I can only suggest either your measurement is at fault or the meters are at fault. Anything which requires so much power from the circuit it is trying to measure is a very poor measurement instrument. Imagine using the analogue meter to measure a 9V PP3 battery? It would almost have discharged the battery before you could establish what its needle was pointing at.
Mike Harding
580199
Follow Up By: Member - Phil G (SA) - Sunday, Jul 06, 2008 at 21:40
Hi Mike,
The readings are OK - used two multimeters.
"Very poor measurement instrument" might be spot on for the analogue voltmeter. It is a 20years old cheapie that I dug out of my electronic junk box, and maybe they have a big coil for the more rugged environment in a car. But people still use them.
The LCD meter use is an
Eflite Power meter - it does a bit more than the average voltmeter and drew 7.3mA. I also recall a Jaycar meter drawing 8mA but it also measured temperature. But they are all meters that are likely to be installed in a vehicle.
580207
Follow Up By: greybeard - Monday, Jul 07, 2008 at 16:55
i think you'll find that you are both be talking about different aspects of a meter.
whilst the input impedance of the electronic meter may be in the order of 10's of Megaohms with microamp current draw you still need to power the actual meter whih is where the 7 odd mA is drawn.
so you'll need ~7mA for the meter itself regardless of what is or isn't measuring and the device being measured will supply the couple of microamps. the current drawn from the cct being measured is not worth worrying about. the current drawn for the meter itself isn't going to do much damage either.
580289
Follow Up By: Mike Harding - Monday, Jul 07, 2008 at 18:13
Any LCD voltmeter which draws 7mA (without a backlight) needs to be redesigned.
My $15 dual temperature meter runs from a single, 1V5, LR44 cell which has a nominal capacity of 150mAh - if the unit were to draw 7mA the cell would last less than 21 hours, instead it lasts for many months. Calculators, watches, central heating controllers etc....
Mike Harding
580300
Follow Up By: greybeard - Monday, Jul 07, 2008 at 18:26
the figure of 7mA was taken from one of the posts above.
i've got a spec sheet for an LCD panel meter in front of me as i type and it is rated at 1mA ( no backlighting ).
it depends upon the device and one would hope that an appropriate device would be chosen. :)
7mA load is ~ 168mA/day
connected to a 100Ah battery and left to drain to 80% capacity gives nearly four months ( 119 days ) of useful life.
i'm not going to worry about it.
have fun out there..
580302
Follow Up By: Mike Harding - Monday, Jul 07, 2008 at 18:47
It's just that you have to consider... if the designers are not competent to design an instrument which meets normal current consumption for such devices... are they competent to design one which produces accurate readings?
Mike Harding
580305
Follow Up By: Member - Phil G (SA) - Monday, Jul 07, 2008 at 19:30
Yep, you get what you pay for.
But I have the choice between spending say an extra $100 on a quality meter or an extra $1.20 to buy a switch that has a "centre off" position.
I too am amazed at the power consumed by the 2" dial voltmeter I measured - thats why it sits in the junk box. I need to keep parasitic losses under control because I ride a bike around town, and the truck sits in the garage for weeks at a time waiting for the next trip.
580310
Reply By: Affordable Batteries & Radiators - Sunday, Jul 06, 2008 at 18:29
This is what you need. Simple 2 way switch.
Derek.
314149
Reply By: Louie the fly - Sunday, Jul 06, 2008 at 18:39
Do I need to take the + lead from the battery terminal on the aux. battery or can I take it directly from the terminal on the aux battery side of the isolator. Same thing really I know but my 2nd battery is in the rear of the vehicle so it would more convenient to do that.
314153
Follow Up By: Member - Phil G (SA) - Sunday, Jul 06, 2008 at 19:29
I prefer to measure at the battery terminals. To measure at the isolator will be fine when you're stopped, but when you're driving and the second battery is taking charge, then voltage drop will not be taken into account.
I use the voltage difference between the two batteries to tell me how much current is being put back into the auxillary battery. And when that difference becomes small, I know that the 2nd battery is nearing full charge.
580188
Reply By: Louie the fly - Sunday, Jul 06, 2008 at 20:11
Thanks everyone for your input here. It's certainly pointed me in the right direction. That's what I like about this
forum.
314172
Reply By: pjd - Monday, Jul 07, 2008 at 09:29
autron do a twin gauge so you can read both all the time
www.autron.com.au
314220
Reply By: Member -Signman - Monday, Jul 07, 2008 at 16:46
Louie
Check out post 57530..
314263
