Is it ok to run a 4wd locked hubs a cupple of kms on the butium
Submitted: Sunday, Jul 06, 2008 at 17:00
ThreadID: 59543 Views:4303 Replies:8 FollowUps:6
Is it ok to run a 4wd locked hubs a cupple of kms on the butium. AS when me and friends go out for a little 4x4 i cant be stuffed get in and out of the 4wd just to lock then in and out
Reply By: stefan P (Penrith NSW) - Sunday, Jul 06, 2008 at 17:11
have the hubs locked all the time if you want, just uses more fuel.
Must take the car out of 4wd though
AnswerID: 314124
Reply By: Ken - Sunday, Jul 06, 2008 at 17:13
unko, you can leave the hubs locked forever if you want , it is putting it in 4WD with them locked on bitumen that is the worry.
Ken
AnswerID: 314126
Reply By: willo82 - Sunday, Jul 06, 2008 at 17:15
to my understanding its ok just as long as your not in 4wd. if your in 4wd on the tar there is no slipping of your tyres and you'll wind your diff. when your not in 4wd your hubs are free and are just spinning. hope this helps
willo
AnswerID: 314127
Reply By: Member - Andrew (QLD) - Sunday, Jul 06, 2008 at 17:29
see thread 59328 for a good response somewhere in that thread.
Might be helpful to use that "spell check" button when posting....and no, they don't have a grammar checker as yet. :-)
Andrew
AnswerID: 314128
Follow Up By: Member - Tony B (QLD) - Sunday, Jul 06, 2008 at 17:52
OK Teacher :-) LOL
FollowupID: 580167
Follow Up By: Member - Andrew (QLD) - Sunday, Jul 06, 2008 at 17:56
Far from it Tony. LOL
just a friendly reminder :-)
Andrew
FollowupID: 580170
Follow Up By: nowimnumberone - Tuesday, Jul 08, 2008 at 17:56
here we go again with the spell checker
did you understand what his post was about?
if so why bother to mention his spelling mistakes he didnt ask if his spelling was good did he?
FollowupID: 580428
Follow Up By: Bonz (Vic) - Tuesday, Jul 08, 2008 at 18:14
and with the greatest of respect to all he spelled the same words twice, maybe thats just the way he spells them
FollowupID: 580434
Follow Up By: Member - Andrew (QLD) - Tuesday, Jul 08, 2008 at 19:09
It's just a friendly reminder, nothing more #1.....sheez.
IMO, it doesn't matter if people spell things incorrectly, however they "may not" know that there is a "spell checker" button down there...that's all.
Andrew
FollowupID: 580449
Reply By: P7OFFROAD Accredited Driver Training - Sunday, Jul 06, 2008 at 17:58
As said, so long as you do not have the car in 4H or 4L (ie be in 2H) you will be fine.
The ground will drive the wheels which will drive the hubs which will drive the axles which will drive the diff which will drive the tailshaft, which will not really do anything...
so... you will use marginally more fuel...
if your vehicle has been lifted you may feel vibration at high speeds...
but you won't wind up or do any damage.
AnswerID: 314138
Reply By: Member - extfilm (NSW) - Sunday, Jul 06, 2008 at 18:21
Hey Unko,
I always forget to unlock the hubs....... Probably done 80 000ks with them locked, and my last tank I got the best fuel economy yet. 10l to the hundred...... I think the nissan had finaly run in after 110 000k
AnswerID: 314147
Reply By: Louie the fly - Sunday, Jul 06, 2008 at 21:02
Methinks in the handbook it says to do this every so often. Something to do with lubricating the internals of the hubs?
AnswerID: 314182
Reply By: Member - joc45 (WA) - Sunday, Jul 06, 2008 at 22:16
Just make sure you have both hubs in the same status; either locked or unlocked.
A mate was relating a story of his mate (yeh, I know I can't vouch for it!) where he drove his current model Patrol with one hub locked and the other on auto for some time. The front diff apparently died and Nissan refused to honour the warranty.
I guess this story will draw comment; I'm not sure what would happen to the diff in this situation, perhaps others could comment. As far as I can see, the free axle will be running backwards, possibly causing abnormal wear to the side and cross gears.
Gerry
AnswerID: 314192
Follow Up By: Lex M - Monday, Jul 07, 2008 at 01:46
Interesting because the auto disconnecting diff sytem that Toyota uses disconnects one axle so it seems to be the same as leaving one hub locked.
See description here
Toyota ADD
FollowupID: 580229
