Performance Chip - 4.8 Patrol
Submitted: Sunday, Jul 06, 2008 at 17:55
Peter L
Can anyone advise me if they have fitted an engine chip to a petrol patrol - 4.8 ??
If so, was any improvement seen in economy and performance.
Thanks.....Peter
Reply By: Notso - Sunday, Jul 06, 2008 at 18:03
The same question was asked over at the Patrol
forumSite Link
314140
Follow Up By: Peter L - Sunday, Jul 06, 2008 at 18:18
Yes I know and no one has responded. Just trying to cover as much of the 4X4 world as possible.
Regards,
580172
Follow Up By: Notso - Sunday, Jul 06, 2008 at 18:40
There's one there that might be useful
"kofoed's
Unichip gave me another 12kw@
wheels. $1395 Fitted and tuned. Shoud be retuned if you make any modifications after the install.
Brings the power on earlier 162kw@3500 as apposed to 150kw@3900. I like it!?
580178
Follow Up By: Peter L - Tuesday, Jul 08, 2008 at 19:59
Thanks Notso...
580463
Reply By: Robin Miller - Sunday, Jul 06, 2008 at 18:24
Hi Peter
Some issues arose when I fited a unichip to
mine and while I have dyno reports that show it put out about 12% more power , I very carefully tried to verify this and was unable to show that there was any improvement.
Issues are that these things work by advancing the static timing
then cutting this back and also changing the injection pulse width.
They only work on open loop.
The people who supply and fit Uni-chips seemed to have little knowledge of how these things really work and set my car up in such a way that it stalled off idle.
I seperately determined that my patrol could not have its static advance moved forward my more than 6 degrees else the ECU would not work properly, after this I set the advance and let them re-tune it from there as best they could.
Mine is a manual and if you have an auto this defect may not be apparant - but check it first yourself.
There are other things to be aware of if you get more serious , but one thing you should do is have some means of accurately determining your cars performance like an acceleromter so that you can see independantly if any installation works.
Seperately to the above I made a microcontroller to overide the oxgen sensor and deliver better economy, this works on closed loop but is not for the faint hearted as it can drive the ecu into a lean error mode.
Over its long life my 4800 has delivered a liveable 16.5 lt/100km
and just last night we got back from a bike ride of Simpson in which my car was driven by someone relatively in-experienced as a support vehicle towing a bike trailer and looks like it achieved a great 24lt-25lt /100km thru the crossing.
(if anyone tells my wife about this reply - there in big trouble)
314148
Follow Up By: Matt(WA) - Sunday, Jul 06, 2008 at 23:11
Hi Robin,
Was watching your prep for your trip! No drama's? Hope you had a good trip. Need to post a trip report.
Matt
580223
Follow Up By: Peter L - Tuesday, Jul 08, 2008 at 19:58
Hi Robin,
Thanks for your response. I am getting about 20lt's per 100 klm's driving to work and I would hate to think what the consumption is when we tow the Outback Jayco. Sounds like you have had a great result.
Did you tinker with the exhaust?
Regards,
580462
