Dual batt setup - getting some wierd results - help needed
Submitted: Monday, Jul 07, 2008 at 22:13
ThreadID: 59571 Views:3207 Replies:8 FollowUps:16
hi guys
i'm a newbie here and i'd hv liked to hv my first post as something different but i need some help/feedback with my DIY dual battery setup.
I hv got a Projecta DIY system and am using a 60ah aux battery which is a generic brand.
i'm running 100amp fused cable (6B&S or 16mm2) to the back of the car from the aux batt. This cable is running into an earthed fuse box (6 fuse box). The earth is at the rear of the car, NOT going back to the aux battery.
From the fuse box, i've connected two Hella style plugs. Taking volt meter readings at main input terminals of the fusebox, and at the minor output terminals shows the aux batt at 12.5V, but when i connect a fridge, the reading drops to around 6V and fridge automatically goes into cutout mode.
Same with when i connect versa lights - when i turn the switch for the light on, the voltmeter reading at the back of the car (fusebox) drops to around 6V and the light simply doesnt come on - just flickers like a fluoro normally does when its trying to turn on.
The fusebox holds blade style fuses of 10am and i've tried changing these to 15amp fuses but it doesnt work.
I'm not an auto electrician so can anyone suggest what would be happening and how i can run further tests
any feedback/assistance would be greatly appreciated.
Jeelan
Reply By: Member - Ed. C. (QLD) - Monday, Jul 07, 2008 at 22:22
When you connected the earth at the rear of the car (to the body, presumably??), did you scrape/sand the paint away??
Aaand, when you earthed the aux. battery (presumably to car body??), did you do the same there as well??
You need clean, shiny metal wherever you connect an earth return to body...
Confucius say.....
AnswerID: 314315
Reply By: Member - Phil G (SA) - Monday, Jul 07, 2008 at 22:22
Measure the voltage on the battery terminals themselves, and if it still drops to 6 volts when you turn on the fridge, I think your battery is cactus. If it no longer drops to 6V, then you've got a bad connection between battery and fuse box. I am assuming that your Aux battery is well earthed to both motor and body.
AnswerID: 314316
Follow Up By: Member - Phil G (SA) - Monday, Jul 07, 2008 at 22:31
I mean battery posts, not terminals.
FollowupID: 580330
Reply By: Member - Brian H (QLD) - Monday, Jul 07, 2008 at 22:38
Well I'll ask the stupid question how olds the battery?. What size cables do you have from the fuse box to the fridge?
I assume there is no problems with the fridge compressor?
I'm sure the fuse I have is a 40 amp, not that I'm saying that's this is the problem. I also seek help here for anything involving wiring lol.
Someone will offer the pearls of wisdom to help you out I'm sure.
They say you get great pleasure in Do it yourself work on your vehicle, I usually need a bigger dose of valium lol.
Brian
AnswerID: 314321
Follow Up By: Member - Jeelan A (WA) - Monday, Jul 07, 2008 at 23:05
hey mate
battery is a new one, only a few weeks old. did the dual batt installation a few weeks ago so its been getting plenty of charge.
Went out this weekend gone for the first time to try the setup.
Fridge was rented - but if fridge was stuffed, then lights should still work. Cabling running from the fusebox to the plugs is all 4mm (core thickness) twin core cabling and cable from aux battery to fusebox (front to rear of the car) is 16mm2 (6B&S cable).
I dont know about valium, but i sure could do with a scotch!!! lol
Jeelan
FollowupID: 580333
Reply By: Member - Jeelan A (WA) - Monday, Jul 07, 2008 at 23:01
the engine bay earth is on clean metal.
The earth at the rear of the car is on painted metal so this might be it.
batt terminals are showing constant 12.5V so battery seems ok.
Fuse box terminals are also showing 12.5V UNTIL an appliance is plugged in or turned on.
If rear earth was the problem, wouldnt the measurements show uneven voltage all the time rather than just when an appliance is attached?
Either way, i'll scrape away some metal and retry....
Jeelan
AnswerID: 314323
Follow Up By: nsngood - Monday, Jul 07, 2008 at 23:10
Sounds like an earth problem to me !
FollowupID: 580334
Follow Up By: Geoff (Newcastle, NSW) - Monday, Jul 07, 2008 at 23:13
"If rear earth was the problem, wouldnt the measurements show uneven voltage all the time rather than just when an appliance is attached?"
Nope, The voltages would look fine without a load (current being drawn) the moment current was drawn the loose or dirty connection would drop volts and die.
Sounds like a loose or dirty connection problem to me too!
Geoff
Geoff,
FollowupID: 580335
Follow Up By: Member - Jeelan A (WA) - Tuesday, Jul 08, 2008 at 00:00
thanks Geoff
i think that's what the problem is. WHen i start the car up, it's all systems go and everything that is connected to the aux battery sockets lights up. Once i've turned the car off, everything runs for about 2 mins and then the lights dim/flicker and fridge goes into cutout mode.
The voltage at the battery posts still reads fine, but at the fuse terminals it starts fluctuating again.
i'll hv to recheck all the terminals and make sure they're connecting well and also check the earth and make sure its completely clean metal .
thanks again for everyone's suggestions..
Jeelan
FollowupID: 580337
Follow Up By: Mainey (wa) - Tuesday, Jul 08, 2008 at 00:18
Jeelan,
Make sure the (thin) 16mm² cable is attached FIRMLY to both the 60ah Aux (+) battery terminal and the 6 lug fuse box (+) terminal.
For *best* result - run a return 16mm² EARTH cable BACK to the AUX (-) battery.
NOW - first check the battery Voltage using BOTH Aux battery posts, then at the INPUT (+) to the fuse box, then check the OUTLET (+) side of the fuse box, with NO load and the EARTH cable attached to a good solid bolt etc for an earth ( because you too far away to use the Neg battery terminal )
Then check same positions with vehicle running and also with load (fridge) attached.
This will show you exactly where the problem is.
Mainey . . .
FollowupID: 580338
Follow Up By: Jeelan - Tuesday, Jul 08, 2008 at 00:57
thanks mainey for that.
I've done pretty much as you've suggested EXCEPT that i dont have a 16mm2 earth going back to the (-) Aux -
the reason i didnt do this was because the firewall hole that i used wasnt large enough to accomodate 2 cables of this thickness plus the co-ax for my UHF. I've decided that i'll drill a larger hole through the firewall and run the earth back to the battery.
Besides that - i have checked voltage on the following
Checked voltage at Aux battery posts - 12.4V
Checked voltage at end of cable in rear of car - 12.4V
checked voltage with cable connected to fusebox - 12.4V (voltage check here was done by touching the fusebox hardware, NOT the cables directly).
Checked the voltage at the OUTPUT terminals of the fusebox - 12.4V
Dismantled a hella socket and checked the voltage here - 12.4V
Ran a load on the system - a cheap 12V compressor which kept sputtering..
Checked voltage at Aux batt posts - 12.4V
Checked voltage at fusebox INPUT terminals - 4-5V reading.
Checked voltage at OUPUT terminals on fusebox - 4-5V reading.
So i guess this means that i've got a bad connection to the fusebox OR that i'm not earthing correctly here.
the 16mm2 cable has been crimped but the crimp for this size cable has a hole that is far too big for the fusebox so i'm using washers under and above the crimp to ensure solid connection - do these washers have to be a specific type to give the best connection??
Same with the (-) terminal - i've used 16mm2 to earth but the crimp for this size cable is much larger than the attachment point on the fusebox so i've used washers to secure.
if all this is fine - perhaps the fusebox is buggered? Is there a simpler system?
I bought the fusebox without giving real thought to what i want to connect - at this point 2-3 hella style points are sufficient for me so is there a simpler, more "robust" method of connection using something like an inline fuse rather than a fusebox as such?
beyond this, the only option is to pull everything out and start reinstalling with dual core cable all the way through....
Incidently, what voltage should a fully charged wet cell battery run at normally anyway? Deep cycle that is...
I've got an Amaron deep cycle which is 60ah and 550CCA. It was a cheaper brand which i deliberately picked because i wasnt sure what my requirements would be etc. I figured once i got a better idea of what i wanted to do with my setup, if required, i could get a higher quality battery.
Jeelan
FollowupID: 580340
Follow Up By: Mainey (wa) - Tuesday, Jul 08, 2008 at 09:25
Jeelan
You have found the problem here:
""Checked voltage @ Aux batt posts - 12.4 Volts""
""Checked voltage @ fuse box *INPUT* TERMINAL --> 4.5 Volts""
""Checked voltage @ fuse box *OUPUT* TERMINAL --> 4.5 Volts""
Simply remedy it by checking the cable connections between the AUX battery terminal and the fuse box *INPUT* terminal, while using the SAME EARTH path.
Because that is where you obviously loose the Voltage...
Mainey . . .
FollowupID: 580353
Follow Up By: Mainey (wa) - Tuesday, Jul 08, 2008 at 09:44
Jeelan,
""Is there a simpler system?"" -> Yes, the most *efficient* method is to run identical (thick) battery cable from the Pos (+) and neg (-) battery terminals direct to the fuse box.
""Beyond this, the only option is to pull everything out and start reinstalling with dual core cable all the way through"" -> Yes and the most *efficient* method anyway !!
""Incidently, what voltage should a fully charged wet cell battery run at normally anyway, Deep cycle that is?"" -> 12.7 Volts
An independant charging cable, both to and from, the fuse box will eliminate Voltage drop and create a secure charging system.
You have stated the DC battery is only 12.4 Volts now, so it's not fully charged anyway!
Mainey . . .
FollowupID: 580355
Follow Up By: oldtrack123 - Tuesday, Jul 08, 2008 at 10:57
Re washers , these form part of the circuit & must be clean bright metal ,brass is best , mild steel next, & STAINLESS last[has highest resistance ].
Mild steel will rust /corrode unless protected with grease / vaseline etc.
You definatly have high resistance joint/joints somewhere in the circuit [ citcuit meaning any where from bat +post back to bat- post.
Agree ,12.4V is not a fully charged battery should be 12. 6v min, you may need to check the bat charging circuit as well
FollowupID: 580369
Follow Up By: Jeelan - Tuesday, Jul 08, 2008 at 11:29
MAINEY -
if i'm reinstalling from scratch, what is the ideal cable that i should use?
I purchased all my hardware from 12V Shop in Welshpool and took their suggestions as to cable size etc.
your earlier comments alluded that 16mm2 is *THIN* - can you pls suggest a type of cable i should be using from Aux batt to fusebox, and then from Fusebox to Hella plugs?
Jeelan
FollowupID: 580376
Follow Up By: Mainey (wa) - Tuesday, Jul 08, 2008 at 18:08
Jeelan,
I use 32mm² (2 B&S) and I only go about 2.5 Metres, I'm not suggesting you should do as I do, but look at the size of "normal" battery cable and a realistic minium of 25mm² would be more useful than 16mm² that you presently use over the 'total' distance to the Hella plugs from the Aux battery.
You can use 25mm² (or larger preferred) to the fuse box, and then use the existing 16mm² to EACH of the Hella plugs, as I understand the distance between the fuse box and each Hella plug will be reasonably short and they will only be running one 'appliance' at a time.
(I have about 1.2 Mtrs of 10mm² powering my fridge, as a comparison)
Remember; when you make the hole in the firewall, use a rubber bung, from a 'garage' or a piece of heavy duty hose or similar 'security' method to stop any rubbing of the battery cable on the (thin) sharp edge of the hole, causing it to SHORT out.
Mainey . . .
FollowupID: 580433
Follow Up By: Jeelan - Tuesday, Jul 08, 2008 at 20:30
mainey
thanks for the additional info - those are some pretty thick cables.
I was initially going to use 4B&S cable but found it too thick to tuck under the door trim of Pajero. The trim werent sitting back properly over the cable so i opted for 6B&S.
i'll hv to reroute through another way i guess.
Also thanks for the heads up with the firewall hole. Again, the 6B&S was the thickest cable that could fit through the existing firewall, however i popped into Repco today and picked up some blank wiring grommets of varying sizes. Will get some hole saws and make a new hole over the weekend and cap off with the appropriate grommets.
Just one final question - basically if i have (-) going back to the Aux batt from the fusebox then i dont need to earth anything at the fusebox...is this correct? The only earth would then be at the Aux Batt itself right?
Jeelan
FollowupID: 580469
Follow Up By: Mainey (wa) - Tuesday, Jul 08, 2008 at 22:01
Jeelan,
You have to form an electrical "circuit"
This electrical "circuit" starts at the (+) terminal of the Aux battery, the (+) cable goes direct to the fuse box, and then a cable goes to each Hella plug via a fuse in the fuse box, then to the "appliance" (fridge or light) and then it returns to the fuse box Neg (-) attachment bolt or similar attachment, then the large (-) cable returns to the (-) terminal of the same AUX battery, forming an electrical "circuit" - when the fuse blows it breaks this electrical circuit.
Most fuse box's have a common earth 'bolt' (attachment) where each (-) cable from the Hella plugs (etc) bolt onto, then your larger (-) cable returns back to the Neg (-) Aux battery terminal, thus forming the electrical "circuit" - ONLY when the "appliance" is connected and activated.
Mainey . . .
FollowupID: 580496
Reply By: Rocky_QLD - Tuesday, Jul 08, 2008 at 07:37
Understanding 12 Volt electrics was once described to me as mirrors, fibre optics and cardboard cut outs.
With 12 volts you have very lttle margin for error, the slightest resistance in the system will cause major problems. As suggested above the best way is to have a positive and a negative cable running from the battery thru the appropriate isolator and fuses.
Rocky
AnswerID: 314333
Reply By: Member -Signman - Tuesday, Jul 08, 2008 at 08:44
An 'earthed' fuse box??
Why would you want to earth the fuse box..If anything it should be insulated..
AnswerID: 314340
Follow Up By: Mainey (wa) - Tuesday, Jul 08, 2008 at 22:19
"" Just one final question - basically if i have (-) going back to the Aux batt from the fusebox then i don't need to EARTH ANYTHING at the fusebox... IS THIS CORRECT ? ""
I read it as a simple question, as it clearly states "just one final question" with the " ? " at the end of the sentence, hence my reply to him.
I don't believe Jeelan is suggesting the actual fuse box is EARTHED
Just asking questions about an "EARTH" to form the electrical circuit !!
Mainey . . .
FollowupID: 580507
Follow Up By: Jeelan - Tuesday, Jul 08, 2008 at 22:32
you got it Mainey - thanks again for the explanation re circuit. I'll run the (-) back to the aux battery and also get the battery checked tomorrow to make sure there's no problems with it.
Jeelan
FollowupID: 580510
Reply By: Jeelan - Tuesday, Jul 08, 2008 at 11:18
THANKS everyone - Mainey your suggestions were great.
As to the comment about washers - i think this might be contributing to the problem. I only had 316 marine steel washers in stock so i've used these quite extensively throughout the install so these might be a large contribution to the problem.
On the weekend i'll be reinstalling the entire setup. I just need to expand on the hole through the firewall so that should allow me to run the appropriate type of cables back and forth.
Thanks again for everyone's help. AS i said in my original post, i'd liked to hv had my intro post as something different but oh well....
ANyway, been lurking around here for a while and picked up a lot of great ideas for my own setup, so now looking forward to participating actively in the forums.
Jeelan
AnswerID: 314368
Reply By: Nomadic Navara - Tuesday, Jul 08, 2008 at 21:12
When chasing voltage loss problems, get a long length of wite to use in the meter negative lead. Connect this to the battery negative terminal. Then measure the system voltage all the way to the load and then back through the negative return to the battery. This checks out both the positive and negative circuits. Doing this is particularly important for caravans and trailers as well.
AnswerID: 314464
