Tojo 2.8D alternator question
Submitted: Friday, Jul 11, 2008 at 18:48
ThreadID: 59683 Views:2578 Replies:3 FollowUps:0
The other week I posted about the trials and tribulations of getting my 4skinner started after it had been sitting for yonks. The alternator pulley had slightly seized but I was able to free it up. Then it was fine.Well, the warden drove it yesterday and it had the same problem for a few moments - smoke everywhere. So I think new alternator bearings are due. Anyone know how to get these things apart? Can you just remove the vacuum pump?
Reply By: Stephen M (NSW) - Friday, Jul 11, 2008 at 20:15
Hi Lou, there were two different pumps/alternators on the LN106 2.8D hilux's (same motor as your 4 runner) One had the pump on the back the other was on the front. I had the one with the pump on the back which you could pull apart. I couldnt tell you about the other one with pump on front which yours probably is been a later model then mine was. I would imagine you could. Isnt this the way the auto sparki's would fix it ??? I had mine done by auto elec but I know the bloke and he showed it to me pulled down so thats how I now that mine did seperate. Regards Steve M
AnswerID: 314858
Reply By: autosparky - Saturday, Jul 12, 2008 at 00:36
both vac pups are servicable. the vac pumps unbolt 3 o 4 screws. and pull away from the main alt shaft. front mounted may have dummy shaft
AnswerID: 314907
Reply By: Louie the fly - Saturday, Jul 12, 2008 at 11:21
Thanks guys. Yes, mine is the front pump model. I might rip it off tomorrow and have a look.
Louie TF
AnswerID: 314946
