Rust Protection after drilling holes
Just wandering what people use to stop rust after drilling a holes to mount something. on the car.
Rich
Reply By: Member - Mark G (NSW) - Saturday, Jul 12, 2008 at 16:52
RICHARD; generally you cant go past the good old fish oil.
AnswerID: 314977
Reply By: mchapo - Saturday, Jul 12, 2008 at 17:13
I use Lanolin
AnswerID: 314985
Follow Up By: Member - Mark G (NSW) - Saturday, Jul 12, 2008 at 17:22
lanolin is good too,as long as what he uses doesnt stink him out of the cab like some rust proofings do
FollowupID: 581052
Follow Up By: Member - Mike DID - Saturday, Jul 12, 2008 at 19:34
Lanolin - it's the most water-resistant grease you can get. Sheep have proven that for millions of years.
FollowupID: 581099
Follow Up By: Twintrail(W.A.) - Sunday, Jul 13, 2008 at 00:46
whale oil is the go if you have any.very hard to locate.
FollowupID: 581170
Follow Up By: Bonz (Vic) - Sunday, Jul 13, 2008 at 17:00
I agree with Mike, Lanolin, I never seen a rusty sheep
FollowupID: 581252
Reply By: Saharaman (aka Geepeem) - Saturday, Jul 12, 2008 at 17:55
Hi Richard,
Yes I agree Lanolin is probably one of the best products to use.
I use the heavy duty industrial lanolin (not the watered down one you get at Sup Cheap or Bunnings)
Try:
www.woollube.com.au
They have it in pressure spray cans, liquid form, or lanolin grease.
Glen
AnswerID: 314993
Follow Up By: richard - Saturday, Jul 12, 2008 at 18:00
Glen,
Is that the right sight, I can't get to it.
Richard
FollowupID: 581063
Reply By: richard - Saturday, Jul 12, 2008 at 18:04
Found http://woolube.com.au/ only one 'L'
AnswerID: 314994
Follow Up By: Saharaman (aka Geepeem) - Saturday, Jul 12, 2008 at 18:07
Yes sorry it has only one "L" in the middle
FollowupID: 581066
Reply By: Member - Phil G (SA) - Saturday, Jul 12, 2008 at 18:12
I use Zinc paint. Used to use fishoil. Both work.
AnswerID: 314996
Reply By: richard - Saturday, Jul 12, 2008 at 18:20
While hunting down the woolube I came across anothe rproduct mentioned called Lanotec - which seems more readily available.
Richard
AnswerID: 314997
Reply By: sfletch - Saturday, Jul 12, 2008 at 18:23
i use silicon to cover the holes,
stays on longer than fish oil / lanolin,
you can put it on your nuts as well,
stops them rattling off !!!
AnswerID: 314999
Follow Up By: richard - Saturday, Jul 12, 2008 at 18:30
Sfletch,
I am drilling holes so I can bolt things down - I have applied silicon to holes before doing this before but was wandering if was a better option.
Richard
FollowupID: 581074
Follow Up By: Bonz (Vic) - Sunday, Jul 13, 2008 at 17:01
doesn't it stick to your jocks?
FollowupID: 581253
Follow Up By: richard - Sunday, Jul 13, 2008 at 17:29
Bonz,
I suspect you were the only one brave enough to comment, but many would have thought it.
Richa
FollowupID: 581261
Follow Up By: Bonz (Vic) - Sunday, Jul 13, 2008 at 17:38
hahahahaha well I will never die wondering thats for sure
FollowupID: 581264
Reply By: RobAck - Sunday, Jul 13, 2008 at 15:41
Richard we find that cold dip galvanising paint is about the best. But you can also use any proprietry rust preventative paint, just let it dry first otherwise you will scrape it off what you are trying to protect. If you go down the paint path then something for marine use is generally the best
RobA
AnswerID: 315112
Follow Up By: richard - Sunday, Jul 13, 2008 at 17:27
RobA,
Any brand names for me to check out,
When you say let dry you mean let dry before putting in screws/bolts.?
Thanks for the reply,
Richard
FollowupID: 581259
Follow Up By: RobAck - Sunday, Jul 13, 2008 at 18:49
Richard no real preference on brands. Cold dip galv paint is available from most places that support metal repairs and maintenance etc and all the good ones are about the same. The thread has mentioned cheap vs better and we support that for sure.
In regard to drying, yep let the paint dry out before putting the bolts/screws in so you don't end up taking the paint off in that process. Patience is a virtue in this instance, which is why I tend to use the galv as it remains pliable and I tend to just drop the bolts into the holes and get on with it.
Another option is to use some of the liquid plastic coatings available on the market and just seal over the whole thing but that comes with its own risks and issues, such as what happens if you want to take the bolt off?
We tend to plan our fitouts and use slightly different methods depending on where the bolts/through body penetration is being done
RobA
FollowupID: 581275
Reply By: geocacher (djcache) - Monday, Jul 14, 2008 at 23:36
Nissan supply this as part of their kit to fit snorkels to Patrols.
You don't need much. Your local Nissan dealer is likey to have a few tubes lying around. It also has a Nissan Part number so you could probably get it via spares.
Australian Inhibitor's G16 corrosion inhibitor
Dave
AnswerID: 315351
