Snow chains
Submitted: Tuesday, Jul 15, 2008 at 11:27
ThreadID: 59784 Views:2816 Replies:4 FollowUps:5
Can anyone tell me what brand and type of snow chain is the best? Ladder and diamond patterns? Also i have got various advise as to which axle to put them on even?? Some advice from experience would be appreciated please.
GN
Reply By: Member - Kiwi Kia - Tuesday, Jul 15, 2008 at 11:49
Diamond pattern have some extra sideways grip. If you really want the best set-up for driving then put them on both axles. This gives you good braking on all wheels and better directional control.
AnswerID: 315400
Follow Up By: Member - G N (VIC) - Tuesday, Jul 15, 2008 at 22:19
Thanks kiwi
i guess that makes sense but i am not looking at serious snow driving realy as i am not so much into the cold country, so probably not required on both axles, plus big expense and more weight?
GN
FollowupID: 581679
Reply By: Member - Oldplodder (QLD) - Tuesday, Jul 15, 2008 at 13:03
Just read an article in one of the latest 4wd magazines about snow chains on new 4wds with ABS and/or traction control.
Evidently not recommended on the front or both axles as it can upset the sensors. Suggest you double check the vehicle manual.
AnswerID: 315412
Follow Up By: Member - G N (VIC) - Tuesday, Jul 15, 2008 at 22:21
Thanks John
good info but my old rig is just that "old" so no issues with all the control from the computor, the only control here is from the helm.
GN
FollowupID: 581680
Reply By: Tony - Tuesday, Jul 15, 2008 at 17:18
KNOIG brand I think are the best. They seem to have the better hookup system, and a very good tension chain.
The one size in Diamond pattern, will do a large range of tyre sizes, from 10R 15 up to and including 265 75 16.
AnswerID: 315450
Follow Up By: Member - G N (VIC) - Tuesday, Jul 15, 2008 at 22:26
Hi Tony
more good info, was looking at Pirana brand but have been stuffed around by conflicting info from pirana and local dealer and now no response so would be happy to get a different brand and the tension / hook up sounds good and worth investigation.
Thanks GN
FollowupID: 581684
Reply By: Member - Kiwi B - Tuesday, Jul 15, 2008 at 17:32
GN
There's an increasing number of vehicles coming on the market these days which don't offer much clearance around the upper suspension joint. Chains fitted to these vehicles can be prone to "throwing" a chain and if they fall in, can be very hard on ABS sensors and brake pipes. Even steering knuckles were a bit of a problem on some solid front-end vehicles with wide tyres fitted.
If they can only be fitted to one end, I always preferred the rear, reason being heading down-hill it's nice to keep the blunt-end at the back. Heading up-hill there was an advantage from weight transfer.
There is room for lotsa discussion on which end is "right" but as in any discussion, each to their own.
We prefer to stay away from the mud and snow these days.
AnswerID: 315453
Follow Up By: Member - G N (VIC) - Tuesday, Jul 15, 2008 at 22:24
mmmm good points Kiwi
I do have solid front and think you may be right on the steer knuckle issue!
If there is no set better option for front or rear then i guess you cant go too far wrong on the rear.
Good info thanks
GN
FollowupID: 581682
Follow Up By: geocacher (djcache) - Tuesday, Jul 15, 2008 at 23:33
Having grown up in the hills I'd say in general that on a four wheel drive, in four wheel drive you are far better off with your chains on the front. You get the combination of traction, direction & braking when & where you want it.
Most of the time in Victoria though you need to carry them to avoid being fined, but rarely need to fit them.
Image Could Not Be Found
Dave
FollowupID: 581697
