I bought the GQ with 265,000km on the speedo 47 months ago.
It was quite pretty sitting in the salesyard with its alloy
wheels and flares.
1994 Nissan GQ RX 4.2litre diesel
Bought in August 2004 for $13,000 with 265,000km on the speedometer.
Accessories fitted after purchase
Snorkel, ARB Bull bar, Electric winch, Battery Tray, Roof Rack $3250 at 270,000km. Less $350 for roof rack sold =$2900
Work done to date:
Normal 5000km Oil changes(sometimes 10,000),
Fuel and Oil Filter changes, Belts and Tyres.
Batteries: 2 x N70ZZ Century Overlander bought 2004 for $308
Removed 7th seats Build storage compartments $50
Replaced
Suspension $1220 OME with 50mm lift at 282,400km
Replaced Flywheel, Clutch and bearings $1500
Replaced
Water Pump $190 at 287,300km
Replaced Aircon torsion pulley $30 at 293,300km
Replaced Alternator belt $20
Replaced Starter Motor $260
Replaced 4 door inserts $100 at 303,000km
Replaced Headlight stalk $50
Replaced 2 bumper tail lights $250
Replaced bushes in panhard rod and rear of radius arm $freebie at 303,000km
Replaced rear Brake Calipers, Brake Pads, Machine Rotors, Flush Brake Fluid $347 at 304,500km
Replace Coolant $30 at 305,000km
Fitted VDO
water temp guage $40 at 305,000km
Fitted Polyairs to rear $480
Fitted Low
Water Alarm $140 at 313900km
Replaced windscreen $285 at 324,900km
Replaced Radiator $500 at 325,000km
Removed Roof Rack at 329,00km
Replaced Windscreen
Water Reservoir pumps $72 at 331,800km
Replaced Steering Damper $110 at 337,600km
Replace storage compartments $50
Replaced Engine Mounts $254 at 345,000
Replaced Front Brake Pads, Rotors and wheel bearings $678 at 345,700km
Replaced Ignition Keys $12 at 345,782km
Removed Steering Lock and Ignition all together as tumbler failed
Replaced Alternator $500
Replaced 2 batteries Century Overlander 4x4 $280
Replaced all belts in bush $52
Running Total so far $10,678
Engine has not been touched. Gearbox has been making noises for a year now. Coachwork has been modified by various dents and scratches. Stuffed a few tyres along the way but have seen some great remote country doing this.
I might give it a wash tomorrow just to celebrate....LOL
