2nd BATTERY NISSAN PATROL 2007 Walkabout
Submitted: Sunday, Jul 20, 2008 at 23:17
Member - Bill S (NSW)
Hi all,
I have just installed second battery and battery management system in our 2007 patrol walkabout. I want to install second battery outlets in the front cab and inside the rear.
I can't find an existing hole thru the firewall. Is there one? Can anybody advise?
Swany
Reply By: Member - John (Vic) - Monday, Jul 21, 2008 at 00:10
The Fitch is probably covering it up :-)
316257
Reply By: Member - DAZA (QLD) - Monday, Jul 21, 2008 at 07:59
Hi Swany
We had the same problem recently, running Cables for the CB and
Brake Controler, I found a small Rubber Grumet in the Fire Wall on
the Passenger side big enough to pull the Aerial Cable through,
and another Grumet on the Driver side, which had to be enlarged
for the Brake Controler Cables and future wiring if needed.
Daza
316280
Follow Up By: Member - Bill S (NSW) - Tuesday, Jul 22, 2008 at 08:27
Thanks all.
Yes! I have been able to squeeze thru the tail of the large grommet behind the glove box after removing some of the tape, then retaping. The small hole to the left of the large grommet is where the CB aerial cable had been placed when I had the CB installed.
Thanks again.
Swany
582744
Reply By: Muzzgit [WA] - Tuesday, Jul 22, 2008 at 01:24
Yeah, same as Dazza I ran them through the large rubber grommet behind the glove box. A real bugger if you have ABS, there's no room for an adult hand.
A perfect spot for the 2pin plug I use for 12 volt is at the bottom of the centre console at the back, basically at the feet of rear passengers. I can have the fridge in the back or on the front
seat, the cable reaches.
If you had to give the airfilter box a bit of a push to get the battery tray in, be carefull you didn't break the seal at the inner guard where the air ducting is simply butted up, not a straight through pipe.
316471
Follow Up By: Member - Bill S (NSW) - Tuesday, Jul 22, 2008 at 08:23
Thanks all.
I used a TJM battery tray which fitted in
well. The Piranha DBE180S battery management system appears to be working
Thanks again.
Swany
582742
