12v electric timer adapter
Submitted: Wednesday, Jul 23, 2008 at 01:28
ThreadID: 60058 Views:5030 Replies:6 FollowUps:6
Hi all. I'm after a 12volt timer adapter to run an older Cooly (mobicool) by Waeco, coolbox. It doesn't have an on/off switch, thermostat, duty cycle etc. It's just a plug and unplugger.
An adapted mechanical timer would do the job, if someone knows how to do it. An electric 12v timer adapter would be simpler if someone knows where I can get one?
Reply By: Member - joc45 (WA) - Wednesday, Jul 23, 2008 at 06:35
you'll have trouble using one of the above, as the motor in the timer is AC and will not run off DC. You could adapt one of the digital timers, as these are already battery operated and use a small relay to switch the power. Would mean pulling it apart tho. If you're going down this path, I'd recommend you do away completely with the 3-pin plug/socket, as running 12v on a 240v outlet will one day result in disaster when someone plugs it into the mains.
cheers,
Gerry
AnswerID: 316688
Reply By: Member - len W SWANSEA (NSW) - Wednesday, Jul 23, 2008 at 06:47
http://www.12volt.com.au/
try here go to see all, down the bottom to timers, i hope this is what your after
...................... len
AnswerID: 316689
Follow Up By: kcandco - Wednesday, Jul 23, 2008 at 20:24
Hi Len
How much are they?
thanks
Kc
FollowupID: 583083
www.12volt.com.au/
AnswerID: 316690
Reply By: traveller2 - Wednesday, Jul 23, 2008 at 08:24
I've got one of those to operate my autofridge in eutectic mode, 2 hrs in the early am and 2 hours in the evening, works a treat, very flexible and easy to program and override back to manual mode if required.
AnswerID: 316699
Reply By: Piscesman - Wednesday, Jul 23, 2008 at 08:24
Joc45, len,thanks for the info and the replies fellas.
len, that 12volt timer is exactly what I'm after.
Good find!
cheers for that,
Dave/Piscesman
AnswerID: 316700
Follow Up By: Piscesman - Wednesday, Jul 23, 2008 at 08:28
Having gotten all excited, I don't know how this one connects ( it doesn't say or show on the 12v site). Anyone know if it's pins or on a lighter socket lead? I'm running the Cooly from a lighter socket adaptor.
FollowupID: 582958
Follow Up By: Member - Cruiser (NSW) - Wednesday, Jul 23, 2008 at 09:33
I have one of these to do exactly what you want and it works a treat. I have it housed in a plastic electrical junction box and i just connected it in between the 12V source and the fridge.
It has a variety of options for the on/off and works really well, even though it is surplus to requirement at the moment.
Cruiser
FollowupID: 582968
Follow Up By: Piscesman - Wednesday, Jul 23, 2008 at 18:31
Found this on the net at Jayc**. I picked it up this arvo, $50. The guys there were really helpful. Suggested I put an 8amp fuse between the timer and the lighter socket, and explained how to wire it all up.
Cruiser, the junction box sounds like a good idea too. I'll be an expert before I know it!
FollowupID: 583050
Follow Up By: Peter 2 - Wednesday, Jul 23, 2008 at 20:20
They have screw terminations across the bottom and come with an instruction leaflet as well.
FollowupID: 583081
Reply By: Thylacine - Wednesday, Jul 23, 2008 at 18:31
Why not use a thermostat instead?
Would give far better temperature control.
ed
AnswerID: 316789
Follow Up By: Piscesman - Wednesday, Jul 23, 2008 at 23:16
Thylacine, you'd better explain what you mean. I'm not that much of an expert.
FollowupID: 583130
