Rear Storage Stage 1 Revisited
Submitted: Friday, Jul 25, 2008 at 18:31
ThreadID: 60145 Views:2716 Replies:3 FollowUps:6
Thank you all for your wonderful suggestions and tongue-in cheek comments et al with reference to post 60105. It is amazing to read of so many Worry-mungerers :-)
This morning I discovered a small technical glitch and have pulled Stage 1 apart and have started again from scratch. Will most likely go with Phil G's suggestion this time around. This however will necessitate more compromise in what I can carry in and how I can store it.
So, you can all wait with bated breath......hahahahaha
Reply By: Member - Phil G (SA) - Friday, Jul 25, 2008 at 19:36
I can't remember what I suggested, but I think it was to get a troopie :-)))
But.......If it were me, I'd have the jerries sitting upright behind the front seats in the footwells, so they can stand upright (or even tilted a bit), and I'd have them well secured to the seat mounts. And that weight is then nicely forward of the rear axle.
AnswerID: 317213
Follow Up By: Willem - Friday, Jul 25, 2008 at 19:45
In the beginning......I looked at Troopy's. I could only afford the 75 series which has such an uncomfortable seating position for me its not funny. Couldn't afford a 78 series which had some modification to the drivers footwell and a slightly better left foot position but still not perfect. The GQ offered the best drivers position of all large 4bies.
Yep, that is what I am doing now. Have installed the base already. Basic footwell and rear of vehicle(all seats removed) is undulating, so a base board is needed, with sides ofcourse and the ability to tie the jerries down. May even get all 9 in plus some water containers. This done I have had to move the fridge back to its old position and thus there will be sleeping place for 1 only. Compromise, compromise....lol
FollowupID: 583504
Reply By: Gramps (NSW) - Friday, Jul 25, 2008 at 19:43
Hmmmm ..... sounds like the penthouse suite may end up as a swag on the ground :)))
AnswerID: 317214
Follow Up By: Willem - Friday, Jul 25, 2008 at 19:53
Many a true word is spoken in jest.
The thought has crossed my mind however. But perish the thought! It is hard enough getting up off the house bed, let alone something on the ground.....I'd be there for half an hour trying to rise with some dignity............LOL
FollowupID: 583505
Follow Up By: Gramps (NSW) - Friday, Jul 25, 2008 at 19:58
Hahahaha I know what you mean. I've given up on the dignity bit .. it's now whatever works on a given day.
FollowupID: 583506
Follow Up By: Member - bushfix - Friday, Jul 25, 2008 at 22:11
too right Al,
sometimes i wake up, and it's so nice out, that I leave it out all day!
FollowupID: 583554
Follow Up By: A J - Saturday, Jul 26, 2008 at 12:43
Willem -have you tried elmore oil for your arthritis - my mother in her 90's uses it and says that it is very good.
www.elmoreoil.com.au
May fix up some of those aches and pains.
AJ
FollowupID: 583609
Follow Up By: Willem - Saturday, Jul 26, 2008 at 17:12
Thanks AJ. Will check it out. ATM using Ballantines Scotch to dull the pain....Mmmmmmmm:-)
bushfix.....the mind boggles...lol
FollowupID: 583653
Reply By: troopyman - Friday, Jul 25, 2008 at 22:09
Packing for a trip is half the fun . Unpacking on the other hand i find not fun . I have seen somewhere on the net some square corners that fit into regular 1 inch steel tube . Just cannot seem to locate it though .
AnswerID: 317256
