Dual Battreys Charges
Submitted: Saturday, Jul 26, 2008 at 12:58
Bat
Hi I have 2 80amps aux batteries in my Toyota which I charge with a Ctek 25amp charger went on power,in my caravan I have one 80amp battery which is charged with a 17amp smart charger ,I used a anderson plug to charge the caravan batties went travelling.My Question is it alright to have the van and the toyota hooked up and use booth chargers at the same time went on power or running a generator. Regards Bat.
Reply By: Member - Olcoolone (S.A) - Saturday, Jul 26, 2008 at 14:40
You can only use one charger at a time unless there are two separate battery circuits.
The Ctek will charge all batterys no problems.
It depends on what battery isolator you are using and how it is set up to whether it will charge the starter battery with the aux batterys together or only the aux batterys.
The ideal isolator should be a two ways current flow type.
317324
Reply By: Bat - Saturday, Jul 26, 2008 at 15:23
Hi, so in other words undo the anderson plug.I am not worry about the starter battery.
317328
Follow Up By: Member -Dodger - Saturday, Jul 26, 2008 at 15:29
YEP. Then unplug the van elec connection 7 pin plug to be sure.
When the anderson plug is unplugged then your vehicles is separate circuit to the van.
583630
