GU clutch/vacuum
Submitted: Saturday, Jul 26, 2008 at 21:51
Member - shane (SA)
I read some time ago about a seal in the clutch master cylinder/vacuum that goes and stops the master cylinder from working, does anyone know about this. the thread was about someone getting caught in the Simpson with the problem.
what i would like to know is which seal is it.
cheers shane.
Reply By: qubert - Saturday, Jul 26, 2008 at 22:10
WHAT IS PROBLEM...?
317405
Follow Up By: Michael ( Moss Vale NSW) - Saturday, Jul 26, 2008 at 22:13
Something to do with the clutch i think... But you never know!!
583737
Follow Up By: Member - shane (SA) - Saturday, Jul 26, 2008 at 22:18
if driving around town or suck using clutch constantly no problem, but don't use it for say 10 minutes it is nearly impossible to change down without pumping the peddle a half a dozen times.
had the fluid changed and bleed twice with no change. no fluid leak and nothing behind the carpet on the inside.
just looking for suggestions. next step is a master cylinder rebuild i think but thought i would ask about the vacuum side.
cheers shane.
583738
Follow Up By: Michael ( Moss Vale NSW) - Saturday, Jul 26, 2008 at 22:42
Probably Master cyl but it could be taking in air from the slave cylinder. I have had that problem in a previous vehicle (Not a 4x4)
Michael
583742
Follow Up By: Michael ( Moss Vale NSW) - Saturday, Jul 26, 2008 at 22:44
Shane, Just check for fluid around the slave cyl first..... You only need a worn cup seal, it can suck air without necessarily letting fluid out in a big way.. Michael
583743
Follow Up By: Michael ( Moss Vale NSW) - Saturday, Jul 26, 2008 at 22:47
The Vacuum booster is only to make the pedal easy to push and is separate from the hydraulics. I bet it gets hard to push the clutch when you pump it 5 or 6 times... Michael
583744
Follow Up By: qubert - Saturday, Jul 26, 2008 at 23:04
needs a new vacuum pump on alternator
583753
Follow Up By: hl - Sunday, Jul 27, 2008 at 08:50
"needs a new vacuum pump on alternator"
Not likely.. the brakes would not work very
well either if that was the case!
Besides, the 3l GU has the vaccum pump in the engine block.
The 2.8 in the rocker cover..
583787
Follow Up By: Member - shane (SA) - Sunday, Jul 27, 2008 at 09:59
vacuum pump on the 4.2 GU is separate under power steering pump, the breaks work fine. yes the peddle does get hard after pumping a few times, there is definitely no fluid at all leaking.
i have ordered a kit for the master cylinder but as usual it has to come from japan, 10 days, think i will do the slave as
IS THIS SOMETHING THAT CANE BE DONE AT HOME by none mechanic?
cheers shane.
583801
Follow Up By: Member - joc45 (WA) - Sunday, Jul 27, 2008 at 12:37
Hi Shane, I know this doesn't help you, but
I've had an intermittent dragging clutch on my 4.2 GU, and while I think it's a dicky spigot bearing, a mate reckons change the clutch master cylinder first, as this is the cheapest option to dropping the gearbox.
So question is, are there after-market master cylinders, or does one have to get a full-price one from Nissan?
cheers,
Gerry
583833
Follow Up By: Member - shane (SA) - Sunday, Jul 27, 2008 at 20:31
hi joc45, my mechanic said there is an after market master and slave cylinder but i am going to get him to put a genuine kit through it first.
I have done 210 000ks on original clutch so that's next i think. will be putting an xtream 60% more pressure clutch and pressure plate. my mechanic is nearly 60 so i will be helping him do the box. this should reduce the price some i hope.
the price for the clutch kit is around $550.00 hear in
Adelaide.
cheers Shane.
583923
