Gu rear tower collapse
Submitted: Sunday, Jul 27, 2008 at 15:37
pepper2
Have just found that the rear drivers side
top spring mount is torn away from the chassis and is resting against the floor heavist van i tow is approx 1500 kg plus minimum gear in vehicle,is there anything special to repairing this ie more than putting back into place welding and adding more steel supports,any advice appreciated thankyou,its a 2002 3litre with 250000k
Reply By: Member - John (Vic) - Sunday, Jul 27, 2008 at 15:57
Its been posted before so its a relatively common thing.
Search the archives as some posts had photos and links to sites of the repairs etc required.
317494
Reply By: Member - gujimbo - Sunday, Jul 27, 2008 at 15:59
Hi pepper2
Atok Auto repairs in Belgrave sth VIC (03 97542751)
make a rear chassis spring mount bracing kit for GQ and GU Patrols, it
is a weld in kit, don't know pricing.
317495
Reply By: Member - Roachie (SA) - Sunday, Jul 27, 2008 at 15:59
Yes, this is a known problem and one which I have been keeping an eye on. When I get my chassis repaired and strengthened soon (see previous thread/s if you don't know what I'm referring to), I will be getting them to weld-in strengtheners for the spring towers too.
Mine were noticed as being cracked about 18 months ago when I had new, heavier
suspension fitted in
Adelaide. The fitter did a welding repair job on them at the time, but now that the chassis is bare at the back of my rig, it is an ideal time to get them strengthened with struts welded to the chassis cross members fore and aft of the towers.
You need to get something done about yours fairly soon as the
fuel lines and brake lines reside on the top of the driver's side tower and they can be crushed if nothing is done.
There is a mob in
Melbourne area called ATOC Engineering who make a strengthening bracket that can be welded in as
well..... but I'm not sure how good it is or how much effort it takes to get it added. I would envisage the body will have to be unbolted and lifted (possibly only slightly......4" or so maybe) in order to get the job done properly.
Good luck.
Roachie
317496
Follow Up By: Nic I (NSW) - Monday, Jul 28, 2008 at 08:47
ATOC have two methods of strengthening rear coil towers:
1. A 'weld-in' kit which you can buy and do yourself, or have it delivered so that someone local to you can do that.
2. A strengthening job that they do, which involves inserting a transverse ladder section and a couple of vertical plates (see photo) This type definitely requires the body to be partially removed, or in the case of a ute, the tray to be removed.
Image Could Not Be Found
They do lots of this type of work, usually after the towers have failed.
583978
Reply By: Member - JohnR (Vic) - Monday, Jul 28, 2008 at 09:32
A plate side to side is what I had in the ute. Weight, air spring assistance, and heavier springs commonly cause the problem in Patrols. They aren't made for heavy gear.
317632
Reply By: Member - Phil G (SA) - Monday, Jul 28, 2008 at 22:53
Here are some pictures done on a new coil cab:
317786
Reply By: Member - joc45 (WA) - Thursday, Jul 31, 2008 at 13:22
Hi Pepper,
Understand how you feel - I've just detected a crack in my GU wagon 2 weeks before heading to
Darwin. Have finally managed to get someone in
Perth who has done these things on Patrols before, and hope to get it fixed next week.
Mine's a wagon, which has never towed anything, but has been
well-loaded in the past.
Have ordered the kit from ASOC in Vic which the local guy will install. He's mainly done utes, so will let you know how he goes with the wagon fix, incl what the ASOC kit is like. The ASOC guys says that the body doesn't have to be lifted, just the axle lowered and springs, etc removed to get access. A longrange
tank complicates the fix a bit.
cheers and commiserations
Gerry
318299
Reply By: pepper2 - Thursday, Jul 31, 2008 at 13:41
Thankyou for the replies,ATOC in melb quoted $300 for the kit for both sides plus $300 labour to install both sides which i thought was reasonable,
318302
