16" x 7" Rim offsets, are they the same for HJ47, 60 seris and 80 seris?
Submitted: Monday, Jul 28, 2008 at 13:27
Member - G N (VIC)
Hi All
Currently running 16" x 7" TRAK 2 "ROH" rims on a 60 seris, are these same rims ok for HJ47 and 80 seris?
I asumed they would bu then got thinking about off sets??????
Regards GN
Reply By: Robin Miller - Monday, Jul 28, 2008 at 14:10
They have best offset you can normally get anyway GN (i.e.
wheels stick out 10mm from centre on both sides) , so you should be right.
Certainly ok on 80 series.
317665
Reply By: Member - Phil G (SA) - Monday, Jul 28, 2008 at 14:35
Measure the backspacing of your ROH rims. If its around 105mm, your rims will fit the 80series fine.
60series and 47series normally have about 80mm backspacing, and 80series about 115mm.
317668
Follow Up By: Member - G N (VIC) - Monday, Jul 28, 2008 at 14:40
Hi Phil
Currently running these rims on 60 seris and they seem fine, so if 80 seris has more space then should be good i guess?
Not sure what you mean on the measure back space?
Do i measure perpindicular from the inner section of the rime where the bolt holes are out to the the inner edge of the rim?Regards GN
584018
Follow Up By: Member - Phil G (SA) - Monday, Jul 28, 2008 at 19:03
Yep, your only problem is that they may stick out too far, but a backspace measurement will answer that.
The easiest way to measure backspace is to lay the wheel face down onto the ground so the backside of the wheel is facing up. Take a straight edge and lay it diagonally across the inboard flange of the wheel. Take a tape measure and measure the distance from where the straight edge contacts the inboard flange to the hub mounting pad of the wheel.
584058
Follow Up By: Member - G N (VIC) - Monday, Jul 28, 2008 at 20:19
Hi Phil
Thank you for effort and good info.
GN
584082
Reply By: Member - Graham H (QLD) - Monday, Jul 28, 2008 at 19:06
Put your
wheels outside down and put a flat object across the rim and measure down to the centre where the stud holes are.
If you clean around the inner rim there is usually the settings of the rim with figures like TOPY and a set of numbers that tell you what is what It is stamped into the metal and can be hard to see unless the rim is clean.
317718
Follow Up By: Member - G N (VIC) - Monday, Jul 28, 2008 at 20:30
Thanks also Graham
584089
