Electronic brake Controllers
Submitted: Monday, Jul 28, 2008 at 14:48
ThreadID: 60245 Views:5652 Replies:6 FollowUps:2
Gooday all. I have had nothing but trouble from my Tekonsha Voyager brake controller. It has always been needing adjusting and has now failed so it is past time for replacement. My question is what to replace it with? I have read that the Tekonsha Prodigy is a good unit and now their latest, the P3 is supposedly the best but on phoning around chasing prices have had the REDARC recommended by no less than three auto eleckies. Does anyone have one of these units and, if so, are they any good. I would go for the REDARC having had one of their battery isolators for a number of years but have never heard of their brake controllers until today.
Reply By: Michael ( Moss Vale NSW) - Monday, Jul 28, 2008 at 15:21
I had 3 on my last Patrol, i got sick of having to get it replaced so i opted for a Hayman Reese.. No more problems.. I also got the Hayman Reese fitted to my current Patrol, I tow a lot and no problems in the last 5 years. Michael
AnswerID: 317672
Follow Up By: Michael ( Moss Vale NSW) - Monday, Jul 28, 2008 at 15:23
The Hayman product can be mounted at any angle as it does not have the pendulum gismo!! Hayman is a more basic unit also.. Michael
FollowupID: 584021
Reply By: Member - Olcoolone (S.A) - Monday, Jul 28, 2008 at 15:35
The Redarc are good units but are not a sophisticated as the Prodogy, the Prodogy gives a lot better progressive control over the Redarc.
Redarc have made brake controllers for over 10 years.
AnswerID: 317673
Reply By: roblin - Monday, Jul 28, 2008 at 15:36
Have a Prodigy. Also can be mounted at acute angles. Have no problems with it and can be purchased at a reasonable price from ABR.
AnswerID: 317674
Reply By: Member -Dodger - Monday, Jul 28, 2008 at 15:38
Go the prodigy and you will find that the wiring you have now will be the same.
The prodigy is far superior IMHO to any other and is easy to adjust plus once set for a particular trailer/van you can forget it. If you change to another van or trailer it is easy to reset.
I too had a Hayman then a Voyager and finally changed to a Prodigy and the difference was chalk and cheese.
Cheers Dodg.
AnswerID: 317676
Follow Up By: Member - Graham H (QLD) - Monday, Jul 28, 2008 at 17:50
I second that bigtime.
Have heard of older Voyagers being replaced out of warranty because of a basic fault.
Why not take it back and try and do a deal on a Prodigy
FollowupID: 584039
Reply By: toyocrusa - Monday, Jul 28, 2008 at 20:02
Hi. I have recently fitted the Prodigy to my Prado and the Prodigy P3 to my brother's new landcruiser 200. Both are excellent units and work well but the P3 is only recommended to be installed horizontally where the prodigy can be installed up to 70 deg angle. The P3 has a better internal program that has more functions and will operate electric/hydraulic brake systems. I contacted the Tekonsha technical people in Melbourne and one thing they were adamant about was that if you have a late vehicle with cruise control then the wire that activates the brake unit should be run from the brake light wire at the REAR of the vehicle, not from the brake light switch. Bob.
AnswerID: 317732
Reply By: Nomadic Navara - Monday, Jul 28, 2008 at 21:37
The Redarc EB1AX http://redarc.com.au/EB1AX.pdf does not apear to have a pendulum or decelarometer in it. I would use it. The Hayman Reese one also does not have either of these and I also would not use it.
AnswerID: 317757
