galvanised fuel tank
Submitted: Monday, Jul 28, 2008 at 21:29
ThreadID: 60262 Views:2308 Replies:3 FollowUps:1
Hello AGAIN. I need to make a long range fuel tank and i thought of making it out of galvanised steel. can anyone tell me if the galvanising lasts in a diesel environment. I know whats involved in welding/cutting it, but need to know of any details affecting fuel qualities. thanks
Reply By: qubert - Monday, Jul 28, 2008 at 21:38
Hold all thoughts. I just read that galvanised steel reacts with some oils . so that idea is out the window.
( why don't i just think normal thoughts ?)
AnswerID: 317758
Reply By: SteveL - Monday, Jul 28, 2008 at 22:50
The aftermarket fuel tank manufacturers mostly use steel that has an aluminium coating.It is available from a few specialty steel suppliers.
AnswerID: 317785
Reply By: Robin Miller - Tuesday, Jul 29, 2008 at 09:01
When I made mine for the Patrol , I just used sheet mild steel and carefully drew it up so that it required minimum bending and painted outside only with kill rust - its all that was required.
Only real issue was to buy fuel grade rubber for the sender seal.
AnswerID: 317815
Follow Up By: SteveL - Wednesday, Jul 30, 2008 at 00:00
Regular mild steel gets a scale along the welded seams which can cause issues when it flakes off.
FollowupID: 584433
