Auto Tune Antenna Installation Q
Submitted: Friday, Aug 01, 2008 at 11:43
ThreadID: 60388 Views:2925 Replies:3 FollowUps:2
Hi all,
I have a uhf radio and antenna that has snapped at the base. The antenna is about 8-10 inches long and is mounted to a hole drilled in the roof rack and goes through a hole in the roof rack. I bought a new one from the West Australia people. Great service. BUT the new one comes with the cable and plug etc attached the plug is soldered on. How do I fit it to my roofrack mount and thread the cable through. THere is a nut on the base but it only for attaching the antenna to the mount. Will I have to cut the cabe and re solder??????
Thanks in advance.
Steve
Reply By: Member - res.q.guy (Vic.) - Friday, Aug 01, 2008 at 12:25
Hi Steve
If it is a bracket on the rack, you could cut a slot in it, otherwise you will need remove and refit the plug.
Neil
AnswerID: 318498
Reply By: Member - Serg (VIC) - Friday, Aug 01, 2008 at 14:51
Steve,
I cannot get you are talking about autotuner HF or about UHF one? Pix will helps enourmously.
Serg
AnswerID: 318516
Follow Up By: Red Patrol - Friday, Aug 01, 2008 at 15:06
Serg,
UHF one. Little antenna one end cable then plug to rear of unit.
Steve
FollowupID: 584960
Follow Up By: Member - Serg (VIC) - Friday, Aug 01, 2008 at 15:12
Well, if you do not like to cut and re-solder cable – easy and preferable option because you can easier put connectornless cable through all small holes – you certainly can extend your mounting hole to slot.
Serg
FollowupID: 584961
Reply By: rredbeak - Friday, Aug 01, 2008 at 21:33
you will probably find the plug is crimped on not solderred. the antenna and cable are tuned to that length,so,if you have to remove the plug then do so without wasting too much coax cable. resolder and call it quits at that...
AnswerID: 318584
