rear lights on pajero working,
Submitted: Saturday, Aug 02, 2008 at 17:44
ThreadID: 60420 Views:2536 Replies:2 FollowUps:2
hi everyone,
trust you all had a good safe week, ok my question for this week, can i get the top rear lights on my pajero working.
i haven't even looked at them yet but thought i'd ask first.is there any law saying i shouldn't as you never know these days,i take it you all know the ones i mean, outside original ones. i am to have all four working if possable.
Reply By: Member - Stephen L (SA) - Saturday, Aug 02, 2008 at 18:07
Hi Sleepy1
If you get hold of 2 stop/tail lamp holders. insert them into the rear back lights, wire them up and you are in business. That is all I did on my previous Pajero.
AnswerID: 318666
Follow Up By: Mike GU - Sunday, Aug 03, 2008 at 02:03
Is it the same for the patrols??
I have seen a few with working hi-level tail lights but as sleepy, I have not looked at them yet
FollowupID: 585251
Follow Up By: Member - Stephen L (SA) - Sunday, Aug 03, 2008 at 10:00
Hi Mike
The lamp holders that I obtained were in fact GMH parts. It is a job that any handy man can do. The only other thing that I should have mentioned is that I had to go to a higher fuse (from memory from 10amp to 15amp), as I still had the original lamps in place, and when I put my brakes on, the extra 2 lamps blew the standard fuse. After that, no problems at all.
FollowupID: 585260
Reply By: Member - Andrew (QLD) - Sunday, Aug 03, 2008 at 09:24
Depends on what model you have, however in many case the tail-light needs to be drilled to fit the bulb holder as it doesn't have the "hole" as such.
Check out the Pajero 4wd Club of Victoria Forum for details on your model and how to do it.
I understood the reason for the lack of brakelights up there was due to the spare wheel location and it obstructing the view of said lights.....theoretically should be no issue if having all 4 working (though i don't know if this is considered legal or not)
Andrew
AnswerID: 318736
