Interesting issues with leaf spring Versus coils.
Submitted: Monday, Aug 04, 2008 at 19:47
ThreadID: 60484 Views:4235 Replies:6 FollowUps:5
Having a chat today with a contracter for Telstra, who has been using GU Nissan tray backs for their associated works, and he stated that when your travelling around rough access tracks with anymore than a tonne on there back the chance of trouble in the rear spring tower area is very high!, He has witnessed a few undersiable things going wrong over the years, including a late model one recentley. Which makes you think , when ive seen leaf springs bent over the other way tyres near rolling off the rim with so much weight, and never a mention about things cracking, maybe a spring leaf now and then,but seldom a chassis related problem. Also the biggest pain , with up to 1.5 t on, its very hard to get going from a stop on a steep incline in low low.
Not a swipe at Nissan, But if your going to build a ute thats capable of carrying a decent load , surely gearing and strength in the right areas is a important issue.
Its blokes like that out in the paddock that tell the true story about any vehicle, not glossy mags, and bull@@@t adds.
Cheers Axle.
Reply By: Crackles - Monday, Aug 04, 2008 at 20:43
It's nothing to do with Leaf V's Coil as your title suggests. It's simply the chassis & the spring mounting that can't carry a load that is at or well over it's rated GVM. I've seen 2 leaf sprung patrols crack in half behind the cab from carrying a constant heavy load, nothing new here. Done correctly like on a Landy, coils can carry a decent load without falling apart.
Cheers Craig.............
AnswerID: 319039
Follow Up By: Member - Axle - Monday, Aug 04, 2008 at 20:52
I own a 130 landy , Its about wheel base more than anything i think!. Not to many lancruiser utes have problems though!
Cheers Axle.
FollowupID: 585533
Follow Up By: Stephen M (NSW) - Monday, Aug 04, 2008 at 20:55
Hi There Craig, not sure of your age but adding to your points above you may remember the old Holdens, HQ'S, Hj,x,z, their one tonne tray backs use to bend behind the cabs. I had seen them over the years where the alloy bar across the top would be resting against the cab, and later model rodeo's cracking in the rear of the chassis. Suspension was all ok. But still good to hear the issues of different vehicles used by tradesman and the like that Axle has mentioned as to what is happening to them. Makes more of us aware of the issues when some one is thinking of buying one for what ever use. Regards Steve M
FollowupID: 585534
Reply By: Willem - Monday, Aug 04, 2008 at 21:19
Axle
Don't think there is a vehicle built that can outlast a Telstra Technician. Going back years now Telstra had issues with Nissan and Toyota alike in 4x4's as the vehicles were and probaby still are, subject to a lot of punishment.
AnswerID: 319056
Follow Up By: Member - Axle - Monday, Aug 04, 2008 at 21:33
I'd say your right Willem!, but a lot of these problems that arise,
Get sorted out, by lesser companys than the manufacturer, which makes you wonder why the hell they don't have a better feedback system so somethings can be rectified?, Falls on deaf ears i guess!.
Cheers Axle.
FollowupID: 585549
Follow Up By: Member - Duncs - Tuesday, Aug 05, 2008 at 08:53
I have seen some of these Telstra Techs driving out west and up on the Cape, what Willem is saying is on the money.
I wouldn't drive a company hire car like that.
As for the problems getting sorted Axle. I called in to the RTA Depot in Broken Hill to ask them what tyres they put on their Patrols for use out in Corner Country.
Never replaced a set of tyres was the answer. The vehicles are traded before 60,000km so most of the problems don't show up before they are sold.
Duncs
FollowupID: 585618
Reply By: Member - Roachie (SA) - Monday, Aug 04, 2008 at 21:25
I think the trouble is that the old-fashioned concept of "build-em tough" has gone out the window at the request of the manufacturers' bean-counters. They've realised that 99% of buyers only use their 4x4s as shopping trolleys and school buses. Those of us who buy their product with a view to using it to (or beyond) it's designed capabilities, can all get stuffed.
They must save a packet by skrimping on the thickness and quality of the steel and welding techniques they emply when building a machine. Do it as cheaply as you can get away with, would be their idea these days.
Sad, but true.
AnswerID: 319061
Follow Up By: OzTroopy - Tuesday, Aug 05, 2008 at 03:42
Yep - I would think that pretty well sums it up.
Additionnally ... coils are great for offroad articulation and also passenger comfort.
When it comes to longterm constant load carrying - I prefer leaf rear springs. Heavy duty ones dont seem to sag as quickly as heavy duty coils .... based on my experience.
FollowupID: 585592
Reply By: Member - Serg (VIC) - Tuesday, Aug 05, 2008 at 06:08
Yep, problem described in OP has nothing to do to coil vs leaf. But if discussed this particular point I would prefer leaf on the back and coils on the front. I use to have LC60 with leafs in all 4 corners and have not got even single issue. Now with LC80 I continuously making around with rear. Yes, I am aware about more travel and more comfort, but with proper setup travel with leaf sufficient for everything, but absolute extreme rock climbing and comfort in any passenger car is far greater that in any “proper” 4WD. In return leaf in the back give you much simple setup in area where you need good clearance (as least 6 pieces of metal gone – two upper, two lower, pahran and stabilizer with all corresponding components), they much more tolerant to overload and even with my heaviest load and stock setup I have not managed bottomed my 60 eve once, while with 80 it happens second time with squashed exhaust. Now I have put stiffest springs from OME, but afraid they still not stiff enough. Coils way too soft. Frankly I have no single problem with them in front. So I am very welcome LC70 setup and know for sure what my next rig will be.
Serg
AnswerID: 319098
Reply By: JR - Tuesday, Aug 05, 2008 at 08:35
Someone said these utes arent capable of a reasonable load!
Look at the load capacity of these trucks especially the coil cabs, then take off a few hundred kg for a "tough" steel tray with full body tool boxes then 2 spare wheels, 160l diesel, Bars, winch etc etc - not much capacity left.
Some of the Telstra utes are Leaf sprung with uprated GVM from new for this reason. They have different chassis too.
They shouldnt have anywhere near 1 tonne on the back of a std coil cab.
I doubt many of them are under standard GVM BEFORE they are loaded up.
The weakest link is actually the axle ratings - ie theres something in them which is rated to 1800kg (leaf axle is Heavier duty)
Real issue here is we keep trying to use Heavy duty cars as trucks. If you need to carry 1.5 tonne up an incline - use a truck rated for it but you have to put up with the downside - speed , comfort, cost and size
Same can be said for wagons.
JR
AnswerID: 319112
Reply By: nutwood - Tuesday, Aug 05, 2008 at 21:26
Simple answer; use the vehicles in the load range for which they were designed.
Once upon a time 4WD's used to be over designed but then the consumers demanded better ride and better economy so the manufacturers obliged.
I reckon the American system is the way to go. A traditional Jeep is a 1/4 ton vehicle, F100 1/2 ton vehicle, F250 3/4ton vehicle and a F350 is a 1 ton vehicle. If you want to load it up, buy a F350.
Most of our common 4wd's are really 1/2 ton vehicles. they can take more, but if you use them off road, or let employee's drive them, you're on borrowed time.
AnswerID: 319264
