Installing a fold down table on a current model Prado.
Submitted: Tuesday, Aug 05, 2008 at 18:43
Kim and Damn Dog
Has anyone done this on the inner back door? I know there are a couple of commercial models, but can't afford the money their asking.
Kim
Reply By: Member - Redbakk (WA) - Tuesday, Aug 05, 2008 at 19:00
Have a look at my profile photo's
319218
Follow Up By: Kim and Damn Dog - Tuesday, Aug 05, 2008 at 19:12
Thanks Redbakk. That's what I'm talking about.
We're going to take off the complicated plastic moulding on Friday and see what we can anchor the MDF table to.
Kim
585773
Follow Up By: Member - Tessa (NSW) - Tuesday, Aug 05, 2008 at 19:50
Kim
Mine is a 90 series and somewhat different but the basic idea remains the same.I would recommend ply rather than MDF. I actually used ply for the backboard and a piece of thick white plastic - like a cutting board - for the table itself. To get any strength in MDF you are going to have to get it quite thick and there is always the problem with swell ing when it gets wet. I put about 7 coats of lacquer on the back board and it wipes clean easily from any splashes and the plastic table is fabulous.Image Could Not Be Found
tessa
585789
Follow Up By: Kim and Damn Dog - Tuesday, Aug 05, 2008 at 20:42
Gidday tessa
Thanks for that. I got a bit motivated by what Willem has done with MDF.
Couple of things I should have mentioned. I sleep in the back of the car and usually leave the back door open in good weather, but I've been caught out a few times.
I take it your recommending ply because of it's
water shredding properties?
Kim
585807
Follow Up By: Member - Tessa (NSW) - Wednesday, Aug 06, 2008 at 07:38
Kim
That and the comparative strength /thickness. I removed the liner from the door and used it as a template to cut the backing board. I guess you could make the back out of MDF, but the table itself, being the full width of the door, requires something fairly strong and waterproof. As you can see I used a piano hinge as
well, which gives more strength. I just think that ply would give you a stronger and more durable finish. BTW, be careful of the watertank for the rear washer when drilling your holes through the door frame. I found out the hard way how far down into the door it projects!
tessa
585859
Reply By: Isuzumu - Tuesday, Aug 05, 2008 at 19:16
Some thing like this
not sure how the door opens on the Prado, but all I did was take the panel off under the window and made a piece of ply to cover it and another on a hinge with some chain to hold it in place when down. Got to be the best thing I have done to the MUs.
Cheers Bruce
319221
Reply By: DesF - Tuesday, Aug 05, 2008 at 19:23
Hi, you just need to make sure the door opens level, my Pajero goes up when opened so I had to mount it at an angle when folded up. but very handy, but mostly use one on the drawers pulled out a bit, seems to have everthing in one place and a lot steadier.
cheers Des.
319223
Reply By: George_M - Tuesday, Aug 05, 2008 at 19:28
Kim
Have a look at
this site for step-by-step instructions.
George
319226
Follow Up By: Kim and Damn Dog - Tuesday, Aug 05, 2008 at 19:46
Gidday George
Thanks very much for that. Great help. Now I know where to screw it in.
PS: Did'nt know there was a Prado site.
Kim
585788
Reply By: Best Off Road - Wednesday, Aug 06, 2008 at 07:49
Kim,
If you're going past pop in and grab a bit of 12mm ply from me, I've got heaps of off cuts. If you let me know the dimensions in advance I'll cut it on the machine for you to save you ballsing around with a power saw.
Jim.
319304
Follow Up By: Kim and Damn Dog - Wednesday, Aug 06, 2008 at 17:57
Thanks Jim
Kim
585976
Reply By: Tenpounder - Wednesday, Aug 06, 2008 at 10:18
Hi there. Just an additional tip. Before you finalise the dimensions of the shelf, make sure that the shelf, when lowered for business, does not prevent access to what's in the back of the vehicle. One common trap is to find you can't pull out the fridge on its trunnion without thumping into the lowered shelf.
From experience, having to lift off the stove, complete with billy, to get the milk out of the fridge, is a PITA.
HAve fun!
319322
Reply By: Member - Col G (WA) - Wednesday, Aug 06, 2008 at 11:05
One small point, I have one of the commercially made units and it is covered in carpet which looks good but is not really the right surface for food preparation.
I would suggest something easily wiped clean.
Col
319332
