GME UHF CB TX 3440
Submitted: Tuesday, Aug 05, 2008 at 19:31
ThreadID: 60513 Views:7650 Replies:8 FollowUps:2
I am thinking about buying a gme tx 3440 cb radio, are they ok as in everything is done on the hand piece. Any foreseeable problems ?
Reply By: oldpop - Tuesday, Aug 05, 2008 at 20:01
Hi Grummo
tx3440 not a bad unit no speaker in hand piece I think the Icom IC-440 a better unit has speaker in hand piece and is
12/24 not much dearer
Oldpop
AnswerID: 319239
Reply By: Scubaroo - Tuesday, Aug 05, 2008 at 20:20
If it's of any use, I've had a TX3400 for 3 years - I've had to resolder the speaker wire back on (done on the road with a 150W inverter and a $12 soldering iron!) - but it's held up great. Survived the Gibb and Kalumbaru roads - the corrugations on those are the ultimate product tests! I'm happy with the GME products.
AnswerID: 319245
Reply By: SteveL - Tuesday, Aug 05, 2008 at 20:31
I would also have a look at the Icom ic-440. I have used the TX3440 and it is a good unit but the Icom gear is generally a bit tougher. The mike on the ic-440 is based on a "command mike"
used for icom marine radios and should be pretty well built.
AnswerID: 319248
Reply By: GaryW - Tuesday, Aug 05, 2008 at 20:49
I've just put a TX3440 in an LC200 - Works very well - I have a hearing problem but have no issues with this unit - main unit is under the glovebox.
I'm a GME fan so I'd be hard pressed to go passed them.
Gary
AnswerID: 319250
Reply By: Member - Stephen L (SA) - Tuesday, Aug 05, 2008 at 21:43
The TX 3440 is a great unit. Very easy to use, full 3 year warranty and most importantly, made here in Australia.
You will not regret buying one.
AnswerID: 319269
Follow Up By: Member - Kiwi Kia - Wednesday, Aug 06, 2008 at 06:58
Are you sure that it is made in Australia ?
FollowupID: 585856
Follow Up By: Member - Stephen L (SA) - Wednesday, Aug 06, 2008 at 08:37
Hi Kiwi Kia
All of the GME Radios that are vehicle mounted are 100% made right here in AUSTRALIA, not overseas. The hand held TX 6200 is also made here in Australia.
The new 3 model small hand helds are the only radios that are made overseas.
FollowupID: 585866
Reply By: Member - Murray R (VIC) - Tuesday, Aug 05, 2008 at 22:53
i have TX3400 not the same model , it is 7yrs old and been switched on 24/7 for most of that time and never had any problens. I also use a external speaker which improves sound quality murray
Another Mexican
AnswerID: 319280
Reply By: SPRINT-GTO - Wednesday, Aug 06, 2008 at 00:15
Yeah I have a GME3440---great unit!!, mounted main unit under drivers seat in my Cruiser and got a standard microphone extension cord and handpiece is plugged in on on dashboard. When parking vehicle for extended periods I just disconnect microphone from dashboard plug and you wouldnt know there was a radio in the vehicle. When mounting to dash use the factory plug holes.
Goodluck
Gary
AnswerID: 319288
Reply By: Holden4th - Wednesday, Aug 06, 2008 at 18:44
I have a TX3400 and it works very well though a strange problem has developed. Running during the day it works perfectly and also at night with the headlights on. But, if I switch on my wipers along with my headlights, the head unit display will flicker. It's especially noticable when going over bumps and at lower speeds. The faster my speed the less the problem occurs. So is this a wiring problem or something more sinister?
AnswerID: 319410
